iPad 5 Wi-Fi Battery Replacement
    1. iPad 5 Wi-Fi Battery Replacement, Heat the left edge: step 1, image 1 of 1
      • Heat an iOpener and apply it to the left edge of the device for two minutes.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement, Screen removal information: step 2, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Screen removal information: step 2, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Screen removal information: step 2, image 3 of 3
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Antennas
      • Display cables
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 4, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 4, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 5, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 5, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    6. iPad 5 Wi-Fi Battery Replacement, Insert an opening pick: step 6, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Insert an opening pick: step 6, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Insert an opening pick: step 6, image 3 of 3
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      Ask FixBot
    7. iPad 5 Wi-Fi Battery Replacement, Separate the left adhesive: step 7, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the left adhesive: step 7, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the left adhesive: step 7, image 3 of 3
      • Insert a second opening pick into the gap you just created.
      • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      Ask FixBot
    8. iPad 5 Wi-Fi Battery Replacement: step 8, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 8, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 8, image 3 of 3
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      Ask FixBot
    9. iPad 5 Wi-Fi Battery Replacement: step 9, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 9, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 9, image 3 of 3
      • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    10. iPad 5 Wi-Fi Battery Replacement, Heat the top edge: step 10, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the device for two minutes.
      Ask FixBot
    11. iPad 5 Wi-Fi Battery Replacement, Separate the top left adhesive: step 11, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the top left adhesive: step 11, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the top left adhesive: step 11, image 3 of 3
      • Rotate the pick around the top-left corner of the device to separate the adhesive.
      Ask FixBot
    12. iPad 5 Wi-Fi Battery Replacement, Separate the top adhesive: step 12, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the top adhesive: step 12, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the top adhesive: step 12, image 3 of 3
      • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      Ask FixBot
    13. iPad 5 Wi-Fi Battery Replacement: step 13, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 13, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 13, image 3 of 3
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      Ask FixBot
    14. iPad 5 Wi-Fi Battery Replacement: step 14, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 14, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 14, image 3 of 3
      • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    15. iPad 5 Wi-Fi Battery Replacement, Heat the right edge: step 15, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the device for two minutes.
      Ask FixBot
    16. iPad 5 Wi-Fi Battery Replacement, Separate the top right adhesive: step 16, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the top right adhesive: step 16, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the top right adhesive: step 16, image 3 of 3
      • Rotate the pick around the top-right corner of the device to separate the adhesive.
      Ask FixBot
    17. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: step 17, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: step 17, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: step 17, image 3 of 3
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • Stop sliding once you reach five inches from the bottom of the iPad to avoid damaging the display cables.
      Ask FixBot
    18. iPad 5 Wi-Fi Battery Replacement, Heat the bottom edge: step 18, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
      Ask FixBot
    19. iPad 5 Wi-Fi Battery Replacement, Separate the bottom left adhesive: step 19, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the bottom left adhesive: step 19, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the bottom left adhesive: step 19, image 3 of 3
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • Leave the pick in the bottom-left corner before moving to the next step.
      Ask FixBot
    20. iPad 5 Wi-Fi Battery Replacement, Separate the bottom adhesive: step 20, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the bottom adhesive: step 20, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the bottom adhesive: step 20, image 3 of 3
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      Ask FixBot
    21. iPad 5 Wi-Fi Battery Replacement: step 21, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 21, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 21, image 3 of 3
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      • Only insert the pick up to 1 mm to avoid damaging the right antenna.
      Ask FixBot
    22. iPad 5 Wi-Fi Battery Replacement: step 22, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 22, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 22, image 3 of 3
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      Ask FixBot
    23. iPad 5 Wi-Fi Battery Replacement, Heat the right edge: step 23, image 1 of 1
      Ask FixBot
    24. iPad 5 Wi-Fi Battery Replacement: step 24, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 24, image 2 of 2
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      Ask FixBot
    25. iPad 5 Wi-Fi Battery Replacement: step 25, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 25, image 2 of 2
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      Ask FixBot
    26. iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: step 26, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: step 26, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Separate the right adhesive: step 26, image 3 of 3
      • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
      Ask FixBot
    27. iPad 5 Wi-Fi Battery Replacement: step 27, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 27, image 2 of 2
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, LCD: step 28, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, LCD: step 28, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, LCD: step 28, image 3 of 3
      • Remove any tape obscuring the LCD screws.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 29, image 1 of 1
      • Remove the following Phillips screws securing the LCD.
      • Three 4.0 mm screws
      • One 4.8 mm screw
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement: step 30, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 30, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 30, image 3 of 3
      • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
      • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
      • Be gentle and keep an eye on the LCD cables as you flip the display over.
      • Lay the LCD on its face to allow access to the display cables.
      • Set the LCD down on a soft, clean, lint-free surface.
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 31, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 31, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 31, image 3 of 3
      Battery Blocker
      $5.95
      Buy
      • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
      • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
      • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
      • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
      • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 32, image 1 of 1
      • Remove the three 1.4 mm Phillips screws from the display cable bracket.
      Ask FixBot
    6. iPad 5 Wi-Fi Battery Replacement: step 33, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 33, image 2 of 2
      • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
      • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
      Ask FixBot
    7. iPad 5 Wi-Fi Battery Replacement: step 34, image 1 of 1
      • Remove the LCD.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, Front Panel Assembly: step 35, image 1 of 2 iPad 5 Wi-Fi Battery Replacement, Front Panel Assembly: step 35, image 2 of 2
      • Remove any tape covering the home button ribbon cable connector.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 36, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 36, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 36, image 3 of 3
      • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
      • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement: step 37, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 37, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 37, image 3 of 3
      • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
      • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 38, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 38, image 2 of 2
      • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 39, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 39, image 2 of 2
      Polyimide Tape
      $9.95
      Buy
      • Remove the front panel assembly.
      • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
      • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
      • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
      • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, Right Antenna: step 40, image 1 of 2 iPad 5 Wi-Fi Battery Replacement, Right Antenna: step 40, image 2 of 2
      • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 41, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 41, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 41, image 3 of 3
      • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
      • Peel the tape up from the rear case.
      • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement: step 42, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 42, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 42, image 3 of 3
      • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
      • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
      • Slide the pick toward the home button to cut the adhesive.
      • Push the bracket away from the speaker until it clears the tape underneath.
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 43, image 1 of 1
      • Remove the following Phillips #000 screws securing the right antenna:
      • One 2.3 mm screw
      • Two 1.4 mm screws
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 44, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 44, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 44, image 3 of 3
      • Insert the flat end of a spudger between the antenna and the speaker assembly.
      • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
      Ask FixBot
    6. iPad 5 Wi-Fi Battery Replacement: step 45, image 1 of 1
      • Remove the right antenna from the iPad.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, Right Speaker: step 46, image 1 of 2 iPad 5 Wi-Fi Battery Replacement, Right Speaker: step 46, image 2 of 2
      • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 47, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 47, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 47, image 3 of 3
      • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
      • Fold the antenna cable out of the way.
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement: step 48, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 48, image 2 of 2
      Buy
      • A bend in the speaker cable makes it difficult to peel the tape up from the end.
      • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
      • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 49, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 49, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 49, image 3 of 3
      • Peel the tape toward the home button to uncover the speaker cable connector.
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 50, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 50, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 50, image 3 of 3
      • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
      • Slide the speaker cable straight out of its ZIF connector.
      Ask FixBot
    6. iPad 5 Wi-Fi Battery Replacement: step 51, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 51, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 51, image 3 of 3
      • Remove the tape holding the speaker to the rear case.
      Ask FixBot
    7. iPad 5 Wi-Fi Battery Replacement: step 52, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 52, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 52, image 3 of 3
      • Carefully peel the LCD buffer tape up off of the rear case.
      Ask FixBot
    8. iPad 5 Wi-Fi Battery Replacement: step 53, image 1 of 1
      • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
      Ask FixBot
    9. iPad 5 Wi-Fi Battery Replacement: step 54, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 54, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 54, image 3 of 3
      • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
      • Pull the speaker down, away from the corner of the case.
      Ask FixBot
    10. iPad 5 Wi-Fi Battery Replacement: step 55, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 55, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 55, image 3 of 3
      • Use a spudger to help pull the speaker out from under the edge of the rear case.
      • Remove the right speaker from the iPad.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, Upper Component Cable Bracket: step 56, image 1 of 1
      • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 57, image 1 of 1
      • Remove the upper component cable bracket.
      • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, Logic Board: step 58, image 1 of 2 iPad 5 Wi-Fi Battery Replacement, Logic Board: step 58, image 2 of 2
      • There are two remaining pieces of tape securing the left antenna cable to the rear case.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 59, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 59, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 59, image 3 of 3
      • Push the bracket away from the speaker until it is clear of the tape underneath.
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement: step 60, image 1 of 1
      • Remove the following Phillips #000 screws:
      • Two 1.4 mm screws
      • One 2.3 mm screw
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 61, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 61, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 61, image 3 of 3
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 62, image 1 of 1
      • Remove the left antenna from the iPad.
      Ask FixBot
    6. iPad 5 Wi-Fi Battery Replacement: step 63, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 63, image 2 of 2
      • Remove the tape covering the left speaker cable connector.
      Ask FixBot
    7. iPad 5 Wi-Fi Battery Replacement: step 64, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 64, image 2 of 2
      • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
      Ask FixBot
    8. iPad 5 Wi-Fi Battery Replacement: step 65, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 65, image 2 of 2
      Ask FixBot
    9. iPad 5 Wi-Fi Battery Replacement: step 66, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 66, image 2 of 2
      Ask FixBot
    10. iPad 5 Wi-Fi Battery Replacement: step 67, image 1 of 1
      Ask FixBot
    11. iPad 5 Wi-Fi Battery Replacement: step 68, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 68, image 2 of 2
      • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
      Ask FixBot
    12. iPad 5 Wi-Fi Battery Replacement: step 69, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 69, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 69, image 3 of 3
      Ask FixBot
    13. iPad 5 Wi-Fi Battery Replacement: step 70, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 70, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 70, image 3 of 3
      • Remove the left speaker from the iPad.
      Ask FixBot
    14. iPad 5 Wi-Fi Battery Replacement: step 71, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 71, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 71, image 3 of 3
      • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
      • Pry up only on the connector—not on the socket itself.
      • Fold the front-facing camera cable out of the way.
      • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
      Ask FixBot
    15. iPad 5 Wi-Fi Battery Replacement: step 72, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 72, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 72, image 3 of 3
      • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
      • Fold the rear-facing camera cable out of the way.
      Ask FixBot
    16. iPad 5 Wi-Fi Battery Replacement: step 73, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 73, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 73, image 3 of 3
      • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
      • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
      • Fold the headphone jack cable out of the way.
      Ask FixBot
    17. iPad 5 Wi-Fi Battery Replacement: step 74, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 74, image 2 of 2
      • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
      Ask FixBot
    18. iPad 5 Wi-Fi Battery Replacement: step 75, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 75, image 2 of 2
      • Remove any tape covering the upper button assembly cable connector.
      Ask FixBot
    19. iPad 5 Wi-Fi Battery Replacement: step 76, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 76, image 2 of 2
      • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
      Ask FixBot
    20. iPad 5 Wi-Fi Battery Replacement: step 77, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 77, image 2 of 2
      • Slide the upper button assembly cable straight out of its ZIF connector.
      Ask FixBot
    21. iPad 5 Wi-Fi Battery Replacement: step 78, image 1 of 1
      • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
      • To find these screws, hold the iPad vertically and look down at the Lightning port.
      Ask FixBot
    22. iPad 5 Wi-Fi Battery Replacement: step 79, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 79, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 79, image 3 of 3
      • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
      • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
      • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
      Ask FixBot
    23. iPad 5 Wi-Fi Battery Replacement: step 80, image 1 of 1
      • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
      • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
      Ask FixBot
    24. iPad 5 Wi-Fi Battery Replacement: step 81, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 81, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 81, image 3 of 3
      • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
      • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
      • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
      Ask FixBot
    25. iPad 5 Wi-Fi Battery Replacement: step 82, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 82, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 82, image 3 of 3
      • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
      Ask FixBot
    26. iPad 5 Wi-Fi Battery Replacement: step 83, image 1 of 1
      • Place a heated iOpener along the bottom edge of the iPad.
      • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
      Ask FixBot
    27. iPad 5 Wi-Fi Battery Replacement: step 84, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 84, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 84, image 3 of 3
      • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
      • Insert an opening pick under the Lightning cable where it meets the logic board.
      • Slide the pick down and around the bend in the cable.
      Ask FixBot
    28. iPad 5 Wi-Fi Battery Replacement: step 85, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 85, image 2 of 2
      • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
      • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
      Ask FixBot
    29. iPad 5 Wi-Fi Battery Replacement: step 86, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 86, image 2 of 2
      • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
      Ask FixBot
    30. iPad 5 Wi-Fi Battery Replacement: step 87, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 87, image 2 of 2
      • Pull the Lightning connector straight out of its recess in the rear case.
      Ask FixBot
    31. iPad 5 Wi-Fi Battery Replacement: step 88, image 1 of 1
      • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
      • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
      Ask FixBot
    32. iPad 5 Wi-Fi Battery Replacement: step 89, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 89, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 89, image 3 of 3
      • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
      • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
      Ask FixBot
    33. iPad 5 Wi-Fi Battery Replacement: step 90, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 90, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 90, image 3 of 3
      • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
      • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
      Ask FixBot
    34. iPad 5 Wi-Fi Battery Replacement: step 91, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 91, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 91, image 3 of 3
      • Slide an opening pick under the logic board between it and the battery.
      • Slide the pick from the base to the center of the logic board to cut the adhesive.
      • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
      Ask FixBot
    35. iPad 5 Wi-Fi Battery Replacement: step 92, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 92, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 92, image 3 of 3
      • Slide the pick up the length of the logic board.
      • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
      Ask FixBot
    36. iPad 5 Wi-Fi Battery Replacement: step 93, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 93, image 2 of 2
      • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
      • Cut any adhesive holding the outer edge of the logic board to the rear case.
      Ask FixBot
    37. iPad 5 Wi-Fi Battery Replacement: step 94, image 1 of 1
      • Remove the logic board from the iPad.
      Ask FixBot
    1. iPad 5 Wi-Fi Battery Replacement, Battery: step 95, image 1 of 3 iPad 5 Wi-Fi Battery Replacement, Battery: step 95, image 2 of 3 iPad 5 Wi-Fi Battery Replacement, Battery: step 95, image 3 of 3
      iFixit Adhesive Remover
      $19.99
      Buy
      • The following steps instruct you to use heat to soften the glue securing the battery. A safer alternative is to inject a solvent, such as iFixit adhesive remover, between the battery and rear case to dissolve the adhesive.
      • Reheat the iOpener in the microwave for 30 seconds.
      • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than 30 seconds.
      • Place the heated iOpener in the center of the back of the iPad. Let it sit there for 90 seconds to soften the battery adhesive.
      • Move the iOpener to the right (away from the rear-facing camera), and let the iOpener sit for another 90 seconds.
      • Finally, move the iOpener to the right-hand edge of the iPad for 90 seconds.
      • The iOpener may cool significantly between sittings—if it does, reheat for another 30 seconds between each position.
      Ask FixBot
    2. iPad 5 Wi-Fi Battery Replacement: step 96, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 96, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 96, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
      • Insert a plastic card under the lower battery cell, at the lower right-hand corner.
      • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
      Ask FixBot
    3. iPad 5 Wi-Fi Battery Replacement: step 97, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 97, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 97, image 3 of 3
      • With the card roughly halfway inserted, slide it toward the top of the iPad, stopping before the battery contact post.
      Ask FixBot
    4. iPad 5 Wi-Fi Battery Replacement: step 98, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 98, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 98, image 3 of 3
      • Lift the card up from the rear case slightly to allow it to pass over the battery contact mounting post.
      • Slide the card from the center of the battery cells to the upper right corner of the battery.
      Ask FixBot
    5. iPad 5 Wi-Fi Battery Replacement: step 99, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 99, image 2 of 2
      • Place a second plastic card about halfway under the left hand battery cell to prevent it from readhering when you reapply the iOpener.
      Ask FixBot
    6. iPad 5 Wi-Fi Battery Replacement: step 100, image 1 of 1
      • Place an iOpener on the right side of the battery, opposite the cards, to loosen the adhesive.
      Ask FixBot
    7. iPad 5 Wi-Fi Battery Replacement: step 101, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 101, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 101, image 3 of 3
      • Slide the card around the lower right corner of the battery.
      Ask FixBot
    8. iPad 5 Wi-Fi Battery Replacement: step 102, image 1 of 2 iPad 5 Wi-Fi Battery Replacement: step 102, image 2 of 2
      • Slide the plastic card to the lower left corner of the battery.
      Ask FixBot
    9. iPad 5 Wi-Fi Battery Replacement: step 103, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 103, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 103, image 3 of 3
      • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
      • Place the plastic card underneath the lower left corner of the battery.
      Ask FixBot
    10. iPad 5 Wi-Fi Battery Replacement: step 104, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 104, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 104, image 3 of 3
      • Slide the card around the upper right corner of the battery.
      • Be extremely careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
      Ask FixBot
    11. iPad 5 Wi-Fi Battery Replacement: step 105, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 105, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 105, image 3 of 3
      • Slide the plastic card to the upper left corner of the battery.
      • Be careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
      Ask FixBot
    12. iPad 5 Wi-Fi Battery Replacement: step 106, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 106, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 106, image 3 of 3
      • Place the plastic card underneath the upper left corner of the battery.
      Ask FixBot
    13. iPad 5 Wi-Fi Battery Replacement: step 107, image 1 of 3 iPad 5 Wi-Fi Battery Replacement: step 107, image 2 of 3 iPad 5 Wi-Fi Battery Replacement: step 107, image 3 of 3
      • Grip both cards firmly and twist them to lift the battery off of the rear case.
      • Remove the battery from the rear case.
      Ask FixBot
58 other people completed this guide.
Evan Noronha
229,815 Reputation
166 Guides authored
11 Guide Comments
Thank you for this guide Evan, worked a treat! Very happy client.
Tom
Tom Ward - Reply Share
Very nice information for the do it yourself person
Kerry Augustson - Reply Share
I finished it replaced the battery but TouchID is not working… sigh and do not have motivation to try again so going to leave it as is.
ztauseef - Reply Share
Buona giorno a tutti,
volevo chiedere perché smontare tutto il pad, quando dopo aver tolto lo schermo basterebbe scollare la batteria e sostituirla?
Grazie per la risposta
Luigi
Luigi - Reply Share
Thanks to this I successfully replaced the battery and glass on my iPad, great job.
Not Playing - Reply Share
Past 24 Hours: 24
Past 7 Days: 148
Past 30 Days: 600
All Time: 64,207
