PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Are these vias broken?
Hi so I removed the analog sticks on my motherboard and I noticed some tears on via in front and Also the bottom one is it bridged? I did a continuity test and got a continuous beeping sound on that trace.
2 Comments
Hi!
I would solder the stick in and see what happens. Cannot see broken traces on the holes that are important. Thanks!
by
Hi, I uploaded a photo of the close-up of the two vias
by
Add a comment
1 Answer
Most Helpful Answer
Hi!
Thank you for the pictures. The traces are a little broken. It’s broken for the “big” hole. But this one is mainly used to keep the stick at place.
If you solder a new stick in, it should work.
Can you try that first and see how that goes?
Thanks
Score 1
Add a comment
Add your answer
Christopher D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 80
