Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in stereoscopic 3D on the top screen.
Charging light but power button does nothing
Hi
I have a 2ds XL that won't turn on, it charges fine and I have tried a known working battery with no luck, the blue light never comes on, I have checked the 2 fuses and they have continuity, I did check for vaultage on the power button but it doesn't seem to be getting any power when pressed, but it gets continuity, wondering where and how I should test from here
Add a comment
1 Answer
Most Helpful Answer
Hi!
You have tested a lot already. Since the battery and fuses are OK, it would be difficult to find where the fault is.
Must be somewhere in the power area near the battery. The power button should work when it gives continuity.
How are the battery pins? Still good? No corrosion?
It could be a lot of things. I think it's easier (I know, it's more expensive..) to get a new motherboard.
Guide: New Nintendo 2DS XL Motherboard Replacement
Score 1
2 Comments:
Well it's more of a want to learn more than a need to fix it lol, guess I just need to learn to follow traces and check where the vaultage stops at this point
by
I would check near the battery, that location!
You can find some more info here: https://gbatemp.net/threads/n2ds-xl-wont...
by
Add a comment
Add your answer
Yelo Hill will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 20
All Time: 208
