New Nintendo 2DS XL Motherboard Replacement
    1. New Nintendo 2DS XL Motherboard Replacement, Prepare for disassembly: step 1, image 1 of 1
      • Before you begin, power off the console and remove:
      • The stylus
      • Any game cartridge
      • The microSD card
      Ask FixBot
    2. New Nintendo 2DS XL Motherboard Replacement, Remove the back cover screws: step 2, image 1 of 1
      • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
      Ask FixBot
    3. New Nintendo 2DS XL Motherboard Replacement, Release the back cover clips: step 3, image 1 of 2 New Nintendo 2DS XL Motherboard Replacement, Release the back cover clips: step 3, image 2 of 2
      • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
      • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
      Ask FixBot
    4. New Nintendo 2DS XL Motherboard Replacement, Disconnect the back cover: step 4, image 1 of 3 New Nintendo 2DS XL Motherboard Replacement, Disconnect the back cover: step 4, image 2 of 3 New Nintendo 2DS XL Motherboard Replacement, Disconnect the back cover: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
      • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
      Ask FixBot
    5. New Nintendo 2DS XL Motherboard Replacement, Battery Removal: step 5, image 1 of 2 New Nintendo 2DS XL Motherboard Replacement, Battery Removal: step 5, image 2 of 2
      • The battery is lightly adhered to its enclosure.
      • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
      Ask FixBot
    1. New Nintendo 2DS XL Motherboard Replacement, Motherboard: step 6, image 1 of 2 New Nintendo 2DS XL Motherboard Replacement, Motherboard: step 6, image 2 of 2
      Buy
      • There are 8 ribbon cables that need to be removed as shown in the picture.
      • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
      • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
      • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
      Ask FixBot
    2. New Nintendo 2DS XL Motherboard Replacement: step 7, image 1 of 2 New Nintendo 2DS XL Motherboard Replacement: step 7, image 2 of 2
      • Unplug the following wires from the motherboard using a pair of tweezers.
      Ask FixBot
    3. New Nintendo 2DS XL Motherboard Replacement: step 8, image 1 of 2 New Nintendo 2DS XL Motherboard Replacement: step 8, image 2 of 2
      • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
      • Remove the motherboard from the device.
      Ask FixBot
13 other people completed this guide.
Caleb Hayhurst
388 Reputation
1 Guide authored
IUPUI, Team S1-G4, Harley Fall 2019 Member of IUPUI, Team S1-G4, Harley Fall 2019
IUPUI-HARLEY-F19S1G4
3 Members
24 Guides authored
7 Guide Comments
On step 6, what is the top left circled connector for?
The screen on the device I am repairing keeping going black and this connector is damaged. (it doesn’t clamp shut)
Can anyone recommend where to buy a replacement board connector?
Billy Holliday - Reply Share
This doesn’t actually give ALL the tools you need. You can’t use a Tri point screwdriver on the CROSS screws that are in the pictures on the motherboard.
tomh1512 - Reply Share
I know this might be a year too late, but the tri point is required for removing the back plate of the system. If you don't have a small philips head laying around your house, idk what to tell ya
Zach Cunningham - Reply Share
Followed on a 2ds having bad input feedback, no major issue. screws on motherboard are cross so you need a small one (most diy nintendo kits have one) and a small clamp (like the one in pictures) is mandatory for the 7 small cables. there is something a bit tricky regarding volume button which is a bit hard to get back in place when you reassemble the console, take care of pushing the inner slider to the most far position for easier mounting.
Arnaud “Kilbane” Jamet - Reply Share
I opened the friction fit connectors before reading this, but I pushed them back down and now my 2ds won't boot. I even tried holding them down to make contact but it still just flashes the backlight and shuts off...
Tipsy The Cat - Reply Share
Past 24 Hours: 14
Past 7 Days: 134
Past 30 Days: 548
All Time: 25,197
