pen drive non trovata
scarico media tool windows 10 ma non trova la pen drive
Update (01/17/26)
USB drive not found
I downloaded the Windows 10 Media Creation Tool but it doesn't detect the USB drive.
USB drive not found
Check the size: The MCT ignores drives under 8GB, shoot for 32GB for best compatibility and for things like storing drivers you may need. It might be the formatting, or the port - try a different port first if you can and do not use a hub. If you are reusing a drive and it has silent issues, it's a thing that occurs with the MCT. Try to format the drive in Explorer, but if you can't, you can do it in Disk Management, but be careful and watch what drive you format. This is where Disk management is:
Verificate le dimensioni: il Media Creation Tool (MCT) ignora le unità inferiori a 8 GB; per una migliore compatibilità e per archiviare file come i driver, è consigliabile utilizzare un'unità da 32 GB. Il problema potrebbe dipendere dalla formattazione o dalla porta USB: provate prima a utilizzare una porta diversa, evitando gli hub USB. Se state riutilizzando un'unità e riscontrate problemi, sappiate che è un inconveniente che può verificarsi con l'MCT. Provate a formattare l'unità tramite Esplora risorse, ma se non ci riuscite, potete farlo tramite Gestione disco. Prestate molta attenzione e assicuratevi di selezionare l'unità corretta. Ecco dove si trova Gestione disco:
MAKE SURE YOU SELECT AND ERASE THE REMOVABLE DRIVE:
ASSICURATI DI SELEZIONARE ED ELIMINARE L'UNITÀ RIMOVIBILE:
Try the MCT tool again - if it still has issues, get a SanDisk drive, SanDisk only. I have had good luck with most name brand drives like PNY, SanDisk and USB3 Kingston models but every time I have found SanDisk drives just tend to work. If you deviate, Verbatims are wonky - they just don't do well with being booted from on the USB2 side. Maybe USB3 is better, but you never see them in stores, so I can't test a USB3 one. I've had little trouble with Windows, but ChromeOS Flex is notoriously bad and Linux is a 50/50 shot. But I wouldn't trust them further then I can throw it because of how bad they handle Linux.
If it keeps being difficult, use Rufus to write the ISO: Windows 10/11 - USB Installation Media Creation (Rufus)
This laptop is old af too, so you need to make sure you format the drive in MBR, NOT GPT. It will ignore your drive with GPT. I have a survivor Compaq F500 with that issue, and a lot of my venerable Dells I love like the D630/D830 and the many unkillable Inspirons have the same issue. The MCT may not accommodate this well, if at all. Use Rufus if it has boot issues. I have dealt with the opposite as well -- USB2 drives crash with a Watchdog violation USB3 drives skirt on AMD platforms with certain SSDs.
Controlla le dimensioni: MCT ignora le unità inferiori a 8 GB, cerca 32 GB per la migliore compatibilità e per cose come la memorizzazione dei driver di cui potresti aver bisogno. Potrebbe essere la formattazione o la porta: prova prima una porta diversa se puoi e non utilizzare un hub. Se stai riutilizzando un'unità e presenta problemi silenziosi, è una cosa che si verifica con l'MCT. Prova a formattare l'unità in Explorer, ma se non puoi, puoi farlo in Gestione disco, ma fai attenzione e guarda quale unità formatti. Qui è dove si trova la gestione del disco:
Verifica le dimensioni: il Media Creation Tool (MCT) ignora le unità inferiori a 8 GB; Per una migliore compatibilità e per archiviare file come il driver, è consigliabile utilizzare un'unità da 32 GB. Il problema potrebbe dipendere dalla formattazione o dalla porta USB: provare prima a utilizzare una porta diversa, evitando gli hub USB. Se state riutilizzando un'unità e riscontrate problemi, sappiate che è un inconveniente che può verificarsi con l'MCT. Provate a formattare l'unità tramite Esplora risorse, ma se non ci riuscite, potete farlo tramite Gestione disco. Prestare molta attenzione e assicurarsi di selezionare l'unità corretta. Ecco dove si trova Gestione disco:
ASSICURARSI DI SELEZIONARE E CANCELLARE L'UNITÀ RIMOVIBILE:
Prova di nuovo lo strumento MCT: se i problemi persistono, procurati un'unità SanDisk, solo SanDisk. Ho avuto fortuna con la maggior parte delle unità di marca come i modelli PNY, SanDisk e USB3 Kingston, ma ogni volta ho scoperto che le unità SanDisk tendono a funzionare. Se devii, i Verbatim sono traballanti: semplicemente non si comportano bene con l'avvio dal lato USB2. Forse USB3 è migliore, ma non li vedi mai nei negozi, quindi non posso testarne uno USB3. Non ho avuto molti problemi con Windows, ma ChromeOS Flex è notoriamente problematico e Linux è un'incognita. Non mi fiderei di questi sistemi operativi, soprattutto per la pessima gestione di Linux.
Se i problemi persistono, usa Rufus per creare l'immagine ISO: [guida|192874]
Questo portatile è molto vecchio, quindi assicurati di formattare l'unità in MBR, NON in GPT. Non riconoscerà l'unità formattata in GPT. Ho un vecchio Compaq F500 con questo problema, e molti dei miei amati e affidabili Dell, come il D630/D830 e i tanti Inspiron indistruttibili, presentano lo stesso problema. Il Media Creation Tool potrebbe non essere compatibile con questa configurazione, o non esserlo affatto. Usa Rufus in caso di problemi di avvio. Ho riscontrato anche il problema opposto: le unità USB 2.0 si bloccano con un errore di Watchdog, mentre le unità USB 3.0 funzionano a fatica su piattaforme AMD con determinate unità SSD.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 119
