Up to 20% off select tools
The original Sony PS3 controller that shipped with the PS3 from 2006-2008 (NO DUAL SHOCK 3)
Charging USB is broken
1 Comment
Could you disassemble it and check if there is continuity with a multimeter? Maybe it's just a solder joint that broke
by Share
Add a comment
1 Answer
Chosen Solution
Hi!
If it’s broken inside (like pins that are bent), you need to replace the port.
Replacing this one is NOT easy. You need to solder and need soldering skills to get it fixed!
Guide: PS3 Dual Shock 3 Controler Charging Port Replacement
Please let us know how it goes!
Score 2
Add a comment
Add your answer
Shutdown Ernest will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 40
All Time: 416
