Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
MacBook Battery Connector Socket/Bracket Broken
hey guys, after i was trying to plug the ribbon battery flex cable back in, i accidentally broke off the bracket and now i don’t know what to do, i want to know if i can still use the mac without this part or like any solutions to fix it. please help, thanks
1 Comment
Ummm... you probably need that part. But only probably. I have no idea where that connector leads (but did you say it lead to the battery?), but knowing Apple's design standards, it probably wouldn't be there if it didn't do something that the computer needs to function. If you really wanted to find out, you could try plugging all the connectors back in and turning the computer on and testing all the functions to find out what it does, if anything. ...Just be careful if you try this. Don't short anything out!
by
Add a comment
1 Answer
Chosen Solution
Sadly, that's the one cable you will have a very hard time finding as it's part of the logic board. Someone who repairs MacBook logic boards maybe able to transfer from a junker a replacement cable. The source I had found last year has disappeared when I needed one.
Score 1
3 Comments:
I found this on aliexpress, can i just use this?
https://www.aliexpress.com/item/10050093...
by
@omar92016 - Good find! Yes that what's needed. You'll need a hot air rework station to re-solder it on. It's not easy as you need a fair amount of heat and some pressure after you tin the pads on both sides just enough not to short across.
by
Alright, thanks man
by
Add a comment
Add your answer
Omar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 246
