Antenna Bar Assembly
4 Answers 1 Score |
Camera does not work and the green light stay off |
6 Answers 3 Score |
FlexGate issue on MacBook Pro M1 2020 (A2338)? |
2 Answers 0 Score |
Weird black screen behaviour when connecting MacBook Pro M1 |
1 Answer 0 Score |
Stage Light Effect on MBP 2020, possible to repair? |
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A2338 (EMC 3578 MacBookPro17,1 Late 2020) 3.2 GHz M1 8-Core
Background and Identification
The late 2020 13” MacBook Pro is updated with Apple’s new M1 chip, marking the start of Apple’s transition away from Intel-based systems. The MacBook Pro 13” Retina Late 2020 joins the MacBook Air 13” Late 2020 and Mac mini Late 2020 as the three devices to initially sport the new Apple silicon. This 13” MacBook Pro is visually identical to the previous model.
Starting at $1299, it is available in either Silver or Space Gray.
Identified by model numbers A2338 / EMC 3578.
Technical Specifications
Display
- 13.3" LED-backlit IPS panel with True Tone; 2560 x 1600 pixels (16:10 aspect ratio, 227 ppi); P3 wide color gamut; Lower resolutions supported
Processor
- Apple M1 3.2 GHz 8-core CPU, 16-core Neural Engine
Graphics
- Apple M1 integrated 8-core GPU
Storage
- 256 GB PCIe-based SSD, configurable to 512 GB, 1 TB, or 2 TB
Memory
- 8 GB of unified memory, configurable to 16 GB
Wireless
- 802.11ax Wi-Fi 6 wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.0 wireless technology
Battery
- Built-in 58.2-watt-hour lithium-polymer battery
- Up to 17 hours of web browsing, up to 20 hours of video playback
Dimensions
- Height: 0.61 in (1.56 cm)
- Width: 11.97 in (30.41 cm)
- Depth: 8.36 in (21.24 cm)
- Weight: 3.0 lbs (1.4 kg)
Ports
- 2× Thunderbolt / USB 4 port (Thunderbolt 3, USB-C 3.1 Gen 2)
- 1× 3.5 mm headphone jack
