IRON Firmware version mismatch
Firmware version mismatch detected.
Please upgrade the iron firmware to ensure optimal performance.
Iron firmware: 1.0.3
Hub firmware: 1.4.2
How to upgrade the iron
Hub firmware: 1.4.2
Did you follow the procedure to update the firmware on both?
I see only option to update the Hub, I Didn't see any option to update the iron. Can you please explain how to update iron firmware ?
@yanivhaddad - Review this guide How to Use the FixHub Web Console
As I mentioned, I did the upgrade according to this tutorial. But there isn't any option to upgrade the iron. Please follow the guide and check.
@krisrodriguez - Any ideas on this one? I thought the same method would work for the iron as well directly connecting it. Is that not the case?
@yanivhaddad, connecting the iron directly to the computer should prompt the console to update. Are you getting any errors? What happens when you plug the iron directly into the computer?
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 21
All Time: 178
