Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Display cable black coating damaged
While changing the battery on my Macbook 1534, some of the black coating on the display cable was damaged. How much of an issue is this likely to be?
Add a comment
1 Answer
So to be clear the solvent removed the coating correct?
If that’s the case I would just her some paint to re-coat the cable as this is only cosmetic. You will need a paint that will stick to the surface. But again this is only needed so the orange ribbon cable is not visible via the space between the case and lid.
Add a comment
Add your answer
Jim Stafford will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 140
