Battery
4 Answers 2 Score |
Any possibility of soldering in a new higher capacity flash drive? |
3 Answers 7 Score |
Little yellow button on logic board - what is it? |
2 Answers 0 Score |
MacBook with FileVault does not erase the disk. |
2 Answers 0 Score |
Can you test the USB-C port w/ multimeter on seemingly dead MacBook? |
Parts
- MacBook 12" Retina (Early 2016-2017) Battery
- MacBook 12" Retina (Early 2016-2017) USB-C Port Assembly
- MacBook 12" Retina (Early 2016-2017) IPD Flex Cable
- MacBook 12" Retina (Early 2015-2017) Display Cable
- MacBook Retina 12" (A1534) Key Caps
- MacBook 12" Retina (Early 2015-2017) Plastic Feet
- MacBook 12" Retina (Early 2015-2017) Lower Case Screw Set
- MacBook 12" Retina (Early 2015-2017) Audio Board Flex Cable
Tools
- Spudger
- iOpener
- Tweezers
- iFixit Opening Tool
- Phillips #00 Screwdriver
- TR8 Torx Security Screwdriver
- Plastic Cards
- Probe and Pick Set
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- iFixit Adhesive Remover
- T5 Torx Screwdriver
- T3 Torx Screwdriver
- iFixit Safety Glasses
- Battery Blocker
- Utility Scissors
- Nitrile Gloves 100 Box
Models
A1534 (EMC 2991 MacBook9,1) 1.1 GHz, A1534 (EMC 2991 MacBook9,1) 1.2 GHz, A1534 (EMC 2991 MacBook9,1) 1.3 GHz
Background and Identification
The Retina MacBook is a member of Apple’s long line of laptops. Released in early 2016, it provides notable upgrades from the previous 2015 version, including a faster processor, longer battery life, increased RAM, and, of course, new colors for its aluminum casing. This 2016 version boasts 10 hours of battery power (for uses such as web browsing) compared to 9 hours in the previous model. With a primary purpose of portability, extended battery life is a key feature in the 2016 version. As with other Apple laptops, the Retina MacBook 2016 has minimized its ports to just one USB-C port located on the left of the device. This offers maximum simplicity or maximum inconvenience, depending on your point of view and intended uses for this device.
This 2016 model is sleek and rectangular in shape. It measures 11.04 inches in length. This model comes in silver, gold, space gray, and rose gold. In all colors, the Apple logo is imprinted on the back of the laptop’s aluminum casing.
Specifications
- Dimensions: 0.14-0.52 x 11.04 x 7.74 inches
- Weight: 2.03 pounds
- Display:
- Size: 12 inches (measured diagonally)
- Resolution: 2304 x 1440
- Processor: 1.1/1.2 GHz
- Memory: 8GB of 1600MHz LPDDR3
- Storage: 256/512 GB
- Camera: 480p front (FaceTime) camera
- Battery: lithium-polymer battery (41.4-watt-hour)
- Use time: 10 hours (internet browsing)
