Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
Easy way to clean stick inside
basically i don’t trust myself to take this thing apart and i don’t wanna bust my ass paying someone else to do it, is there an easy way to stop stick drifting to the right without stripping it apart?
2 Comments
Hi!
Which stick do you mean actually? The DSi doesn't use any joystick.
by
My bad i mean the analogue button like the left right up down button, it’s sticking so it’s always pressing right
by
Add a comment
1 Answer
Most Helpful Answer
Hi Kaine!
Ah you mean the D-pad!
For this you do need to open up the console, but it's really easy to do!
You might want to replace the rubber and clean it there. You do NOT need to remove the motherboard, only the power board to access the d-pad button and rubber.
Clean the power board carefully (and the d-pad conductive buttons on there). And the d-pad plastic button as well. Replace the rubber for a new one and it should be good to go!
Guide: Nintendo DSi XL D-pad Replacement
Part: https://www.ebay.com/itm/354393945198
With this guide, you can determine if you want to do it by yourself or let someone else do it for you.
If one of the conductive pads failed, damaged and could not be cleaned anymore, I advise to fully replace the power board. Easier then soldering the conductive pads off. That part can be found here: https://www.ebay.com/itm/354118222468?_t...
But try cleaning first! Most of the times this will fix it.
Score 1
Add a comment
Add your answer
kaine roberts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 275
