Nintendo DSi XL D-pad Replacement
    1. Nintendo DSi XL D-pad Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL D-pad Replacement, Battery: step 1, image 2 of 2
      • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
      • Lift the battery cover off the back of the DSi XL.
      Ask FixBot
    2. Nintendo DSi XL D-pad Replacement: step 2, image 1 of 1
      • Lift the battery from the DSi XL.
      Ask FixBot
    1. Nintendo DSi XL D-pad Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL D-pad Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL D-pad Replacement, Lower Case: step 3, image 3 of 3
      • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
      Ask FixBot
    2. Nintendo DSi XL D-pad Replacement: step 4, image 1 of 1
      • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
      • Four silver 5.3 mm screws
      • Two black 5.3 mm screws
      • One black 2.5 mm screw
      Ask FixBot
    3. Nintendo DSi XL D-pad Replacement: step 5, image 1 of 3 Nintendo DSi XL D-pad Replacement: step 5, image 2 of 3 Nintendo DSi XL D-pad Replacement: step 5, image 3 of 3
      • Turn the DSi XL over, and open the display.
      • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
      • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
      Ask FixBot
    4. Nintendo DSi XL D-pad Replacement: step 6, image 1 of 2 Nintendo DSi XL D-pad Replacement: step 6, image 2 of 2
      • Close the display and turn the DSi XL over.
      • Lift the lower case from the front edge.
      • Rotate the lower case away from the DSi.
      • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
      Ask FixBot
    5. Nintendo DSi XL D-pad Replacement: step 7, image 1 of 2 Nintendo DSi XL D-pad Replacement: step 7, image 2 of 2
      • Using a spudger, pry the SD card/right shoulder button connector off its socket.
      • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
      Ask FixBot
    1. Nintendo DSi XL D-pad Replacement, Power Board: step 8, image 1 of 2 Nintendo DSi XL D-pad Replacement, Power Board: step 8, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
      • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
      Ask FixBot
    2. Nintendo DSi XL D-pad Replacement: step 9, image 1 of 1
      • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
      • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
      Ask FixBot
    3. Nintendo DSi XL D-pad Replacement: step 10, image 1 of 2 Nintendo DSi XL D-pad Replacement: step 10, image 2 of 2
      • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
      • Lift the power board off the upper case.
      Ask FixBot
    1. Nintendo DSi XL D-pad Replacement, D-pad: step 11, image 1 of 1
      • Lift the rubber pad off the back of the D-pad.
      Ask FixBot
    2. Nintendo DSi XL D-pad Replacement: step 12, image 1 of 2 Nintendo DSi XL D-pad Replacement: step 12, image 2 of 2
      • Open the display slightly, and push the D-pad up through the upper case.
      • Lift the D-Pad from the handheld device.
      Ask FixBot
10 other people completed this guide.
Brett Hartt
132,360 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
1 Guide Comment
Be very careful removing the screws - a Google search returns page after page of people who stripped their screws trying to remove the lower case or the power board. My lower case may be permanently attached now. If I did it over again, I would consider dripping a tiny amount of WD40 onto the screws and letting it seep in for a day before I tried removing them...
Nick Noble - Reply Share
Past 24 Hours: 8
Past 7 Days: 31
Past 30 Days: 179
All Time: 14,801
