Repair and disassembly information for Google's Pixel 8 smartphone, released in October 2023. Identified by model numbers G9BQD, GA04851-US, GKWS6, GPJ41, and GZPFO.
do I need to replace the adhesive?
If I open it up do I need to replace the adhesive?
Score 1
1 Comment
Short answer. Yes.
Longer answer. Depending on where you open it up you may damage the adhesive and it will be safer to replace it than not doing it. Replacing it will also ensure liquid resistance is kept.
by
Add a comment
1 Answer
Most Helpful Answer
I would recommend replacing the adhesive after you open the device up. The adhesive helps ensure dirt, dust, and water doesn't get into the device. Not replacing the adhesive could result in moisture damage, which would end up costing you far more than the relatively small investment.
Google Pixel 8 Screen Adhesive - Genuine
This custom cut adhesive film secures the display panel to the frame of a Google Pixel 8 smartphone. Image
Product
$3.99
Score 1
Add a comment
Add your answer
Grayden Hormes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 294
