Up to 20% off select tools
Guides
Documents
Models
G9BQD, GA04851-US, GKWS6, GPJ41, GZPFO
Background
Announced on October 4th, 2023, the Pixel 8 continues Google's flagship smartphone with updates to its camera and processor. While the camera itself hasn't changed from the Pixel 7, the new Google AI integration allows for higher quality photos for smaller objects, a.k.a. "Macro Focus," and more options for in-app editing. The Google AI is possible via the new Google Tensor G3 processor, which has improved performance and efficiency compared to the Tensor G2.
The Google Pixel 8 starts at $699 USD.
Identification
The Pixel 8 can be identified primarily by its model number: GKWS6 or G9BQD, which can be accessed by looking at its original box or navigating to "Settings" >"About phone" and then scrolling down and tapping on "Model & Hardware."
If you lost the original box or can't access the Settings app on your device, you can also identify the Pixel 8 by its signature camera bar that protrudes as a wide strip along the top edge of the back cover. Compared to the Pixel 7 that had one oval-shaped camera cutout alongside a circular cutout, the Pixel 8's camera cutout is a single oval. The screen is also a little smaller at 6.2 inches compared to the Pixel 7's 6.3 inches.
The Pixel 8 comes in three colors: Hazel, Mint, Obsidian, and Rose.
Repairability
For a detailed look at the pros and cons of repairing the Pixel 8, see the attached report.
Repair Snapshot Pixel 8
Technical Specifications
  • CPU: Nona-core (1x3.0 GHz Cortex-X3 & 4x2.45 GHz Cortex-A715 & 4x2.15 GHz Cortex-A510)
  • GPU: Immortalis-G715s MC10
  • Chipset: Google Tensor G3 (4nm)
  • Memory: 8 GB LPDDR5X RAM
  • Storage: 128/256 GB internal memory
  • Display
    • 6.2 inch panel
    • 1080 x 2400 pixels (~428 ppi)
    • Actua OLED, HDR10+, 60–120Hz
  • Cameras
    • Main Camera: Dual-lens camera with 50 MP, f/1.7, 25mm (wide), 1/1.31", 1.2µm, multi-directional PDAF, Laser AF, OIS 12 MP, f/2.2, 126˚ (ultrawide), 1/2.9", 1.25µm
    • Front-facing Camera: 10.5 MP, f/2.2, 20mm (ultrawide), 1/3.1", 1.22µm, PDAF
    • Google AI Integration
  • Ports and Connectivity
    • Wi-Fi 802.11 a/b/g/n/ac/6e/7, tri-band, Wi-Fi Direct, hotspot
    • 5G Sub 6GHz / mmWave, LTE
    • Bluetooth v5.3
    • GPS, GLONASS, BDS, GALILEO, QZSS, NFC
    • USB Type-C 3.2
  • Battery:
    • Li-Ion 4575 mAh battery
    • Fast charging 27W
  • Dimensions
    • Size: 150.5 x 70.8 x 8.9 mm (5.93 x 2.79 x 0.35 in)
    • Weight: 187 g (6.60 oz)
  • Additional Features
    • IP68 water/dust resistance rating (1 meter underwater up to 30 minutes)
    • Stereo speakers
    • Fingerprint (under display, optical)
    • Laser AF
Additional Information
Author
with
tayola
10,505 Reputation
44 Guides authored
Kid fixers Member of Kid fixers
Community
229 Members
2,196 Guides authored
Past 24 Hours: 58
Past 7 Days: 384
Past 30 Days: 1,919
All Time: 84,096
