The JBL Clip 4 is a small portable speaker which released in December 2020. Identified by side of the speaker on the carabiner opposite to the Bluetooth button, it will say "Clip 4".
Not working after fall in pool
It was submerged for about 10sec max, took it out, started playing again.
Stopped after a few minutes, never turned on again. Isnt it supposed to be waterproof?
Score 1
Add a comment
Chosen Solution
Yes, it has an IP67 rating for ingress protection, meaning it should be waterproof. However, depending on how badly you have use/wore down the device, it only needs one or two cracks/holes for water to seep in through and corrode. My thinking is that it is water damaged.
Score 1
Add a comment
ip67 означает что он влагостойкий, например можно использовать во время дождя.
ip68 означает что он водонепроницаемый. например можно полностью погружать в воду, но не глубже чем 1 метр и не дольше чем 30 минут
Add a comment
Add your answer
Raf Mertens will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 628
