The Lenovo IdeaPad 3-15ALC6 (also known as Lenovo IdeaPad 3 15ALC6 or IdeaPad 3 15, model 82KU) is a 15.6-inch budget-friendly laptop powered by AMD Ryzen 5000 series processors. This device is part of Lenovo’s IdeaPad 3 lineup and is commonly searched for repairs involving the display, keyboard, battery, and SSD upgrades.
My CPU fan stopped spinning
I originally just wanted to open up my bottom case to check for dust bunnies and tighten up some loose screws
My CPU fan stopped spinning up and when booting into Windows I checked hwinfo to check my temps because it seemed warm, I was peaking at 95⁰C (red)!
Did I accidentally disconnect something from the fan?
Add a comment
1 Answer
Most Helpful Answer
Hi @hchun70596
If this is the same laptop that has the bent chassis, then perhaps the fan has become disconnected from the motherboard due to that problem.
Here's the hardware maintenance manual for the laptop.
Go to p.46 to view the procedure to remove the fan. This will allow you to check the fan cable connection and also ascertain the problem with the chassis.
It may be a good idea to add more images in your other question showing what has happened to the chassis. Initially it looks like the hinges may have come loose but the image doesn't show it too well. Here's how to add images to an existing question on ifixit Adding images to an existing question
Score 1
Add a comment
Add your answer
H. Chun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 22
All Time: 439
