3 Answers 0 Score |
How and Why did my chassis bend? |
2 Answers 0 Score |
The screen stopped displaying an image |
1 Answer 1 Score |
What size is the barrel jack port? |
1 Answer 1 Score |
Is it possible and worthwhile to install a backlight into this laptop? |
Models
82KU, 82MF
Background
The Lenovo IdeaPad 3-15ALC6 is part of Lenovo’s IdeaPad 3 lineup, which was introduced as an affordable and practical laptop series aimed at everyday users. Released in 2021, this specific model is built on the AMD Ryzen 5000 processor platform, making it a capable device for web browsing, streaming, light productivity, and even some casual gaming. With a 15.6-inch display, it strikes a balance between portability and usability, appealing to students, home users, and professionals who need a dependable computer without the premium price tag of Lenovo’s higher-end series like the ThinkPad.
The IdeaPad family itself has roots going back to 2008, when Lenovo first launched the brand as a consumer-oriented alternative to its business-focused ThinkPad series. While ThinkPads are known for durability and enterprise features, IdeaPads have consistently been designed to be budget-friendly, stylish, and functional for personal use. Over the years, Lenovo has expanded the IdeaPad lineup to include a range of screen sizes and hardware configurations, covering entry-level users up to more performance-driven models. The 3-series, including the 3-15ALC6, sits at the entry level, making it one of the more common models people seek help repairing or upgrading.
As a budget laptop, the IdeaPad 3-15ALC6 makes compromises compared to higher-end machines, often featuring simpler cooling solutions, fewer upgrade options, and basic build materials. However, it remains a popular choice because of its balance of cost and performance, especially when paired with SSD storage and Ryzen CPUs. Users often look to repair or upgrade components such as the battery, keyboard, and storage drive to extend the device’s lifespan.
For more information about Lenovo as a manufacturer, you can read about them on https://en.wikipedia.org/wiki/Lenovo
Identification
The Lenovo IdeaPad 3-15ALC6 can be identified as a 15.6-inch laptop with a slim, lightweight design and a plastic chassis that typically comes in colors such as Arctic Grey, Abyss Blue, or Sand. The laptop has a full keyboard layout with a numeric keypad on the right, a centered touchpad below the keyboard, and a thin-bezel display that helps distinguish it from older IdeaPad models with thicker borders. To confirm the exact model, users should check the bottom of the laptop, where a label or sticker lists the model name (IdeaPad 3-15ALC6) and machine type number (often beginning with 82KU). Unlike other Lenovo series such as the ThinkPad, the IdeaPad 3 does not carry a red TrackPoint in the middle of the keyboard, which makes it easier to distinguish. These visual and physical features, along with the printed model information on the underside of the device, make it possible to tell the IdeaPad 3-15ALC6 apart from other Lenovo laptops.
Technical Specifications
Memory (RAM)
Up to 16 GB DDR4-3200
One SO-DIMM slot + some soldered RAM (varies by configuration)
Storage
Single M.2 PCIe NVMe SSD slot (supports 2242 / 2280 sizes)
Ports & I/O
1 × USB-C (USB 3.2 Gen 1)
1 × USB-A 3.2 Gen 1
1 × USB-A 2.0
1 × HDMI 1.4b
1 × 3.5 mm headphone/microphone combo jack
SD / MicroSD card reader (on select SKUs)
Battery / Power
Lithium-ion / Li-polymer battery (typically 45 Wh)
65 W AC adapter
Physical / Dimensions / Weight
Dimensions: ~ 359.2 × 236.5 × 19.9 mm
Weight: ~ 1.65 kg (≈ 3.64 lb)
Sources
Lenovo PSREF: IdeaPad 3 15ALC6 spec sheet (psref.lenovo.com)
TradeInn spec listing (tradeinn.com)
LDLC retailer listing (ldlc.com)
