The OnePlus 8T is an Android smartphone manufactured by OnePlus, released on 16 October 2020.
How to replace only glass part of screen panel?
OnePlus 8T+ screen cracked after falling out of pocket.
OtterBox cases aren't all they say to be apparently. The OLED panel itself of the screen is completely fine, it's only the glass that's broken. How much would this be to fix? How can I fix it? I see that panels are around $150 but is there a way to replace just the glass? Would I be better off sending it to someone to fix than trying to fix it myself? I don't have any tools to fix it, and would like to keep costs as low as possible. Thanks.
Add a comment
1 Answer
@mrmcfeffers a one time glass only repair is anything but cheap. You'll spend more money on just the tools and consumable then a new display assembly would cost. Since you also have never done one, you would need more pieces since this would not be an easy repair. You potentially could get it cheaper but those will be regular LCd screens and not the AMOLED that your phone has. Places like this are always good for low to mediocre quality for the screens. As for the actual physical replacement, you'd have to use the 8T and then progess slowly to compensate for any differences between those two models OnePlus 8T Screen Replacement
Add a comment
Add your answer
Mrmcfeffers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 508
