Up to 20% off select tools
OnePlus 8T Screen Replacement
Views: 35K
View statistics:
Past 24 Hours:
11
Past 7 Days:
83
Past 30 Days:
394
All Time:
35,240
Comments: 12
6 comments on steps, 6 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen on your OnePlus 8T.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. OnePlus 8T Screen Replacement, Step 1  Remove the SIM tray: step 1, image 1 of 1
      • Before you begin, switch off your phone
      • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the bottom right edge of the phone.
      • Press firmly to eject the tray
      • Remove sim card tray
      Ask FixBot
    1. OnePlus 8T Screen Replacement, Heat the rear glass: step 2, image 1 of 1
      • Switch off your phone.
      • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. OnePlus 8T Screen Replacement, Create a gap: step 3, image 1 of 3 OnePlus 8T Screen Replacement, Create a gap: step 3, image 2 of 3 OnePlus 8T Screen Replacement, Create a gap: step 3, image 3 of 3
      • Apply a suction cup to the back of the phone, as close as possible to the center of the bottom edge.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull on the suction cup to create a gap between the rear glass and the frame.
      • Insert the tip of an opening pick into the gap and slide it to the bottom left corner.
      • Leave the opening pick in its place to prevent the adhesive from resealing.
      Ask FixBot
    3. OnePlus 8T Screen Replacement, Slice the adhesive: step 4, image 1 of 2 OnePlus 8T Screen Replacement, Slice the adhesive: step 4, image 2 of 2
      • Insert a second opening under the bottom left corner.
      • Slide the opening pick along the bottom edge to the bottom right corner.
      • Leave the pick in its place to prevent the adhesive from resealing.
      Ask FixBot
    4. OnePlus 8T Screen Replacement, Slice the adhesive: step 5, image 1 of 3 OnePlus 8T Screen Replacement, Slice the adhesive: step 5, image 2 of 3 OnePlus 8T Screen Replacement, Slice the adhesive: step 5, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick under the bottom right corner.
      • Slide the opening pick along the right edge to the top right corner.
      • Leave the opening picks in their place to prevent the adhesive from resealing.
      Ask FixBot
    5. OnePlus 8T Screen Replacement, Slice the adhesive: step 6, image 1 of 2 OnePlus 8T Screen Replacement, Slice the adhesive: step 6, image 2 of 2
      • Insert a fourth opening pick under the top right corner.
      • Slide it along the top edge to the top left corner to cut the adhesive.
      Ask FixBot
    6. OnePlus 8T Screen Replacement, Slice the remaining adhesive: step 7, image 1 of 3 OnePlus 8T Screen Replacement, Slice the remaining adhesive: step 7, image 2 of 3 OnePlus 8T Screen Replacement, Slice the remaining adhesive: step 7, image 3 of 3
      • Insert a fifth opening pick under the top left corner.
      • Slide the opening pick along the left edge to the bottom left corner to cut the remaining adhesive.
      Ask FixBot
    7. OnePlus 8T Screen Replacement, Remove the rear glass: step 8, image 1 of 1
      • Remove the rear glass.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. OnePlus 8T Screen Replacement, Unscrew the motherboard cover: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
      Ask FixBot
    2. OnePlus 8T Screen Replacement, Unclip the motherboard cover: step 10, image 1 of 3 OnePlus 8T Screen Replacement, Unclip the motherboard cover: step 10, image 2 of 3 OnePlus 8T Screen Replacement, Unclip the motherboard cover: step 10, image 3 of 3
      • Insert the tip of an opening pick under the bottom left corner of the motherboard cover.
      • Use the opening pick to lift the motherboard cover up and release the plastic clips that hold it in place.
      Ask FixBot
    3. OnePlus 8T Screen Replacement, Remove the motherboard cover: step 11, image 1 of 1
      • Remove the motherboard cover.
      Ask FixBot
    4. OnePlus 8T Screen Replacement, Disconnect the battery: step 12, image 1 of 2 OnePlus 8T Screen Replacement, Disconnect the battery: step 12, image 2 of 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
    1. OnePlus 8T Screen Replacement, Unscrew the daughterboard cover: step 13, image 1 of 1
      • Use a Phillips screwdriver to remove the seven 3.8 mm-long screws securing the daughterboard cover.
      Ask FixBot
    2. OnePlus 8T Screen Replacement, Remove the daughterboard cover: step 14, image 1 of 3 OnePlus 8T Screen Replacement, Remove the daughterboard cover: step 14, image 2 of 3 OnePlus 8T Screen Replacement, Remove the daughterboard cover: step 14, image 3 of 3
      • Insert the tip of an opening pick under the top edge of the daughterboard cover.
      • Remove the daughterboard cover.
      Ask FixBot
    3. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: step 15, image 1 of 2 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: step 15, image 2 of 2
      • Use a spudger to disconnect the first fingerprint sensor connector by prying it straight up from its socket.
      Ask FixBot
    4. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: step 16, image 1 of 2 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: step 16, image 2 of 2
      • Use a spudger to disconnect the second fingerprint sensor connector by prying it straight up from its socket.
      Ask FixBot
    5. OnePlus 8T Screen Replacement, Disconnect the interconnect cable: step 17, image 1 of 2 OnePlus 8T Screen Replacement, Disconnect the interconnect cable: step 17, image 2 of 2
      • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
      Ask FixBot
    6. OnePlus 8T Screen Replacement, Disconnect the antenna cables: step 18, image 1 of 3 OnePlus 8T Screen Replacement, Disconnect the antenna cables: step 18, image 2 of 3 OnePlus 8T Screen Replacement, Disconnect the antenna cables: step 18, image 3 of 3
      • Carefully disconnect the two antenna cables by prying them straight up from the daughterboard.
      Ask FixBot
    7. OnePlus 8T Screen Replacement, Unscrew the daughterboard: step 19, image 1 of 1
      • Use a Phillips screwdriver to remove the 3.1 mm-long screw securing the daughterboard.
      Ask FixBot
    8. OnePlus 8T Screen Replacement, Separate the daughterboard: step 20, image 1 of 2 OnePlus 8T Screen Replacement, Separate the daughterboard: step 20, image 2 of 2
      • Use an opening pick to pry up the daughterboard.
      • Use your fingers to separate the daughterboard from the phone assembly.
      Ask FixBot
    9. OnePlus 8T Screen Replacement, Disconnect the screen: step 21, image 1 of 2 OnePlus 8T Screen Replacement, Disconnect the screen: step 21, image 2 of 2
      • Use the flat edge of a spudger to pry up and disconnect the screen connector from its socket at the frame.
      Ask FixBot
    10. OnePlus 8T Screen Replacement, Heat the screen: step 22, image 1 of 1
      • Heat an iOpener and apply it to the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    11. OnePlus 8T Screen Replacement, Create a gap: step 23, image 1 of 2 OnePlus 8T Screen Replacement, Create a gap: step 23, image 2 of 2
      • Apply a suction cup to the right edge of the screen.
      • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull the suction cup up with strong, steady force to create a gap.
      • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
      Ask FixBot
    12. OnePlus 8T Screen Replacement, Slice the adhesive: step 24, image 1 of 3 OnePlus 8T Screen Replacement, Slice the adhesive: step 24, image 2 of 3 OnePlus 8T Screen Replacement, Slice the adhesive: step 24, image 3 of 3
      • Insert a second opening pick at the bottom right corner.
      • Leave both opening picks in their place to prevent the adhesive from resealing.
      Ask FixBot
    13. OnePlus 8T Screen Replacement, Slice the adhesive: step 25, image 1 of 2 OnePlus 8T Screen Replacement, Slice the adhesive: step 25, image 2 of 2
      • Slide the opening pick along the bottom edge to the bottom left corner to slice the adhesive.
      • Leave the pick in its place to prevent then adhesive from resealing.
      Ask FixBot
    14. OnePlus 8T Screen Replacement, Slice the adhesive: step 26, image 1 of 3 OnePlus 8T Screen Replacement, Slice the adhesive: step 26, image 2 of 3 OnePlus 8T Screen Replacement, Slice the adhesive: step 26, image 3 of 3
      • Insert a fourth opening pick under the bottom left corner.
      • Slide the opening pick along the left edge to the top left corner to slice the adhesive.
      Ask FixBot
    15. OnePlus 8T Screen Replacement, Slice the adhesive: step 27, image 1 of 2 OnePlus 8T Screen Replacement, Slice the adhesive: step 27, image 2 of 2
      • Slide the opening pick along the top edge to the top right corner.
      • When you slice near the front facing camera, insert only the tip (5 mm) of the opening pick to avoid damaging the camera.
      • Do not remove the screen completely yet. The display cable is still threaded through the midframe.
      Ask FixBot
    16. OnePlus 8T Screen Replacement, Separate the screen: step 28, image 1 of 2 OnePlus 8T Screen Replacement, Separate the screen: step 28, image 2 of 2
      • Thread the display flex cable through the gap in the frame.
      Ask FixBot
    17. OnePlus 8T Screen Replacement, Remove the screen: step 29, image 1 of 1
      • Remove the screen.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
12 other people completed this guide.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
6 Guide Comments
Thank you iFixit & Adriana! These intructions are spot on and guided me perfectly through a successful front and rear screen replacement.
Jim M.
Jim Malinak - Reply Share
Hi Jim, we're happy to hear that we were able to help you with your repair!
Adriana Zwink - Reply Share
I broke my phone one plus 8T just now, how should i proceed next ? I want it really to be fixed but not sure if its still in a condition that i can be repaired
Akshay Raina - Reply Share
Do you remove the front earpiece speaker grill as well when you remove the front screen? As I am putting the screen back on, not sure if the top of the screen needs to be under the grill, but for some reason, it isn't matching or it's bulging from that area.
Erik Stejanko - Reply Share
WARNING!
You have to remove the sim card tray before removing the daughterboard. At nno point in this guide is this mentioned. You risk damaging the daughterboard when trying to pry it loose.
Staffan Näs - Reply Share
Past 24 Hours: 11
Past 7 Days: 83
Past 30 Days: 394
All Time: 35,240
