A heat gun is a device used to emit a stream of hot air, usually at temperatures between 100 °C and 550 °C (200-1000 °F), with some hotter models running around 760 °C (1400 °F), which can be held by hand.
Works only on lower settings
My B&D KX1693 works fine on settings 1 & 2 but when put on 3 nothing happens, the fan is not on and no heat produced.
Any ideas?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @cjd85004
It could be a faulty setting switch.
Although if it is and this is your model, there aren't many spare parts available anymore.
Score 1
Add a comment
Add your answer
Cjd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 360
