Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Heat guns have a wide array of takes they can be employed for. Some of these uses are, to strip paint, shrink heat shrink tubing, shrink film, and shrink wrap packaging, dry out damp wood, bend and weld plastic, soften adhesives, and thaw frozen pipes.
The most comon use of heat guns here on iFixit are however, in electronics to desolder and rework surface-mounted circuit board components. Heat guns are also used for functional testing of overheat protection devices, in order to safely simulate an overheat condition. Although the "gun" type can be used for these tasks, an inexpensive hot air station is recommended for this line of work.
Author
with
Sam Goldheart
478,971 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 39
Past 7 Days: 132
Past 30 Days: 574
All Time: 32,187
