The Wacom Intuos Pro is a graphic design tablet designed by Wacom. The device comes with, a type-C charger, the Pro pen 2, and the Pen holder.
Removing battery for USB only usage?
Is possible to simply remove the battery inside PTH-660? In a studio setup, it is not really needed. USB is better!
Score 2
Add a comment
Most Helpful Answer
You can remove the battery but you'll need a soldering iron. You can follow this ifixit guide here.
Score 1
Add a comment
OK, thanks, but removing the battery puts the tablet in "USB Only" mode?
Nevermind the question.
I removed the battery and I can confirm: the tablet Works Without the battery. Just a brief message that the battery il low, but after that IT WORKS
Score 1
Add a comment
Add your answer
Luca Di Meo will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 43
All Time: 1,220
