Wacom Intuos Pro Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
4
Past 7 Days:
46
Past 30 Days:
245
All Time:
12,384
Comments: 15
8 comments on steps, 7 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you begin to notice that your battery doesn’t seem to be charging, or isn’t holding a charge like it used to, then it may be time to replace it. This guide will walk you through the steps to replace the battery in your Wacom Intuos Pro. Replacing the battery of your device should restore its charge capacity and lifespan to near new conditions.
Tools
    1. Wacom Intuos Pro Battery Replacement, Battery: step 1, image 1 of 3 Wacom Intuos Pro Battery Replacement, Battery: step 1, image 2 of 3 Wacom Intuos Pro Battery Replacement, Battery: step 1, image 3 of 3
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
      Ask FixBot
    2. Wacom Intuos Pro Battery Replacement: step 2, image 1 of 3 Wacom Intuos Pro Battery Replacement: step 2, image 2 of 3 Wacom Intuos Pro Battery Replacement: step 2, image 3 of 3
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
      Ask FixBot
    3. Wacom Intuos Pro Battery Replacement: step 3, image 1 of 2 Wacom Intuos Pro Battery Replacement: step 3, image 2 of 2
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
      Ask FixBot
    4. Wacom Intuos Pro Battery Replacement: step 4, image 1 of 2 Wacom Intuos Pro Battery Replacement: step 4, image 2 of 2
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
      Ask FixBot
    5. Wacom Intuos Pro Battery Replacement: step 5, image 1 of 2 Wacom Intuos Pro Battery Replacement: step 5, image 2 of 2
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
      Ask FixBot
3 other people completed this guide.
7 Guide Comments
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - Reply Share
Do you know where can I find the battery replacement?
Valerio _ - Reply Share
Has anyone got a lint to the replacement battery?
Luca Di Meo - Reply Share
PTH-660 works fine without the battery, just remove it and use it with USB cable
Where can I find a replacement battery for this model?
Denise Hanly - Reply Share
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 245
All Time: 12,384
