Up to 20% off select tools
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
Power locks just quit working
Power locks just quit working all together. Checked fuses, replaced door button, and replaced power lock/anti theft actuator and still nothing
Add a comment
1 Answer
These are all controlled via the Body Control Module. This type of vehicle has some of this operation built into the engine computer too. The relays carbon-up &/or go dry-jointed inside of the BCM's. They need a re-work and relay contacts all need cleaning, which you can do yourself by pinching a non-glossy business card between the relay contacts and sliding it out until the black carbon trace disappears. De-solder, clean, flux, re-solder dry joints on relays and connectors. I've personally done hundreds over many years.
Add a comment
Add your answer
Josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 396
