Up to 20% off select tools
Documents
Models
This category covers 1997, 1998, 1999, 2000, 2001, 2002 Ford Expedition models.
Background and Identification
First introduced in 1997, the Expedition sits between the smaller Explorer and the larger Excursion in Ford's SUV line.
Standard equipment on the first-generation Expedition included a 4.6 L V8 engine and 4-speed automatic transmission; a 5.4 L V8 engine was offered as an option. Both rear-wheel drive and four-wheel drive versions were made. Trim packages included the entry-level XLT and the top-end "Eddie Bauer" model.
Many repair procedures for the Expedition are similar to both the F-150 pickup on which it is based, and the Lincoln Navigator, which is a more luxury-oriented model with the same mechanical underpinnings.
Additional Information
Ford, Lincoln and Mercury A/C Service Tech Tips, 1992–2003
1997–2003 Ford F-150 / 1997–2002 Expedition Front Bumper Replacement Installation Instructions
Metra 99-5802 Ford/Lincoln/Mazda/Mercury Radio Dash Kit Installation Instructions
Metra 95-5818 Ford/Lincoln Double DIN Dash Kit Installation Instructions
Aeromotive 14117 Fuel Rail Installation Instructions for Ford 5.4L F-150, Expedition and F-250
Ford, Lincoln and Mercury Passive Anti-Theft System Diagnostic Service Tips (TSB 01-6-2)
Dorman 742-272 Motor Elevador de Ventana: Instrucciones de Instalación/Eliminación
Dorman 741-873 Window Regulator Installation and Removal Instructions
WJ1020-0750/WJ10-0014 Ford F-150, F-150 Heritage and Expedition Headlights User Manual
Ford TSB 02-1-9: SAE 5W-20 and 5W-30 Oil Applications for Gasoline and Flex Fuel Vehicles
Ford TSB 03-14-8: New Transmission Cooler Flusher Service Tips
Ford Article 01-20-5 Vacuum Leak Detection Service Procedure
Ford Technical Service Bulletin 02-16-4 Fuel Pump Whining/Buzzing Radio Noise
Ford Article 01-10-12 Wire Harness Terminal Repair Kit and Wire Splice Procedure
Ford Article 01-15-6: Repeat Heater Core Failure
Ford Article 03-18-1: Remote Keyless Entry Service Tips
Ford, Lincoln and Mercury Exterior Mirror Glass and Motor Replacement Service Bulletin 03-23-2
Ford Motor Company Propylene Glycol-Based Engine Coolant Position TSB 01-23-6
Ford Engine Oil System Priming Procedures Service Bulletin 01-24-6
Ford Lincoln Mercury Electrical Wiring Soldering and Crimping Repairs Service Bulletin 03-11-6
Ford Article 02-11-4 Engine Gasket Remover and Service Tips
Ford Technical Service Bulletin 01-15-7 Transmission Fluid Usage
Ford Article 02-17-6: Brake Lamp Modifications Disabling Brake Shift Interlock
Ford Article 02-21-13: Checking Cylinder Head and Block Flatness
Author
with
Jeff Suovanen
455,865 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 8
Past 7 Days: 21
Past 30 Days: 95
All Time: 14,327
