Repair guides and specifications of the HP Envy 17t, released in 2017. The HP Envy 17t has a 17" display, 16GB of RAM, and an Intel Core i7 processor.
Why is my computer overheating while off completely?
I have an HP Envy 17t that is a few months over a year old and the problems that it has started a few months after and Hp customer support is no help, the main issue is that it will be completely shut down and it will overheat to the point of burning my hand. I have tried everything that I know to try and find the issue to the extent of making it a brick with no software on it, then reuploading it. I have also found that when I open the lid the lights will sometimes be on as well, and it kills my battery. I am now desperate for information on this problem, because I have thought of everything I know, and it hasn't helped.
Score 2
Add a comment
1 Answer
Most Helpful Answer
There's a couple of things you're going to want to do.
  • Make sure that your machine's air vents are clear of any debris or dust
  • Open the device up and make sure that the cooling fan is clean actually running
  • Ensure that your CPU's surface is clean and has a proper amount of thermal paste.
I did find a guide on how to get into the device to inspect the internals. I'll link it here, but you'll only need steps 1 - 11. I'd also attach pictures if you do get the opportunity.
iFixit Image
Guide
Adding images to an existing question
Difficulty:
Very easy
2 - 5 minutes
HP Envy 17t Display Panel Image
Guide
HP 17t-k000 Series Display Panel Replacement
Difficulty:
Moderate
1 - 2 hours
Score 1
Add a comment
Add your answer
Justin Boge will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 319
