Up to 20% off select tools
Nest's 3rd-generation learning thermostat. Released on September 1st of 2015. Model numbers: T3007EF, T3007ES, T3008US, T3010FD, T3010GB, T3016US, T3017US, T3018US, T3019US, T3021US, T3032US.
How to drain battery
The iFixit instructions with the replacement battery says to charge, drain, and charge. Does anyone know how to drain the battery in a consistent way and how long does it take to do so. Obviously, reconnecting the thermostat back to the base won’t work since it can charge from the base.
Add a comment
1 Answer
Most Helpful Answer
Hi @sscollis ,
Try disconnecting the power from the base.
As to how long it takes would depend on how much charge the battery has and what the load current is. I don’t know the answer to this.
Score 1
2 Comments:
If you disconnect the "C" wire (probably blue) it will probably drain. Might take several days and inevitably will die at 2 am when it's 95 degrees out and you will wake up in a hot sweat! Personally I think that whole "memory" thing with batteries is left over from old NiCAD batteries and likely unnecessary for this application.
by Share
@nicksartor Nowadays the charge/drain instructions are not for the benefit of the battery "memory", but rather for the sake of battery health calibration to establish a full/empty baseline for monitoring the battery charge.
by Share
Add a comment
Add your answer
Sam Collis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 1,001
