Up to 20% off select tools
Guides
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
T3007EF, T3007ES, T3008US, T3010FD, T3010GB, T3016US, T3017US, T3018US, T3019US, T3021US, T3032US
Background
The Nest Learning Thermostat 3rd Generation is the third rendition of the smart thermostat developed by Nest Labs. The device employs machine learning, meaning it first collects data on home temperature settings to build a reference set. Then, the device learns from the data it collects what temperatures home inhabitants prefer at different times throughout the day. Additionally, the Nest Learning Thermostat can use built-in sensors and the location of home inhabitants’ phones to determine when people are home. This intelligence enables the device to be as energy-efficient as possible by only heating/cooling the home when necessary.
The Nest Learning Thermostat 3rd Generation has a circular face. It is designed to mount on a wall, and it extends 1.21 inches out from its mounting position. The thermostat has a 3.3-inch screen. The circular border around the screen is black in color, while the rest of the device is stainless steel. The encasing comes in a variety of colors, including white, black, copper, polished steel, mirror black, brass, and stainless steel.
Identification
Specifications
  • Dimensions: 3.3 inches in diameter
  • Weight: 8.6 ounces
  • Material: Stainless steel
  • Display: 24-bit color LCD
  • Battery: lithium-ion (rechargeable)
  • Warranty: two-year limited warranty
  • In the Box:
    • Nest Learning Thermostat 3rd Generation
    • Screwdriver
    • Screws
    • Trim kit
Additional Information
Author
with
Taylor Dixon
73,293 Reputation
94 Guides authored
Past 24 Hours: 8
Past 7 Days: 60
Past 30 Days: 205
All Time: 12,754
