Up to 20% off select tools
An external optical drive by Apple, essentially a rebranding of the MacBook Air SuperDrive.
Can broken cable be fixed?
Cable has cracked at the mount point on the drive and drive is no longer working - is not getting power. Can I open the drive up & get access? Is the cable replaceable?
Add a comment
1 Answer
Most Helpful Answer
It will take some doing! Follow this guide Apple USB SuperDrive Optical Drive Replacement once you have it opened up you should be able to de-solder the cable.
Now the fun begins! Using a 3D CAD program design a new strain relief block. Start by making an exact match to Apples part. Create a threaded end over the cable so you can thread on a threaded collar to hold the pieces together. Now split it in half (Top/Bottom) making room for the replacement cable you’ll want to use, and lastly create the collar piece. Find a friend or someone who can 3D print the parts (hopefully you have no errors) You may need to tweak the design a few times.
Score 2
1 Comment:
I wish I had the skills to do this!
by Share
Add a comment
Add your answer
c.schrey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 32
All Time: 658
