The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Service Battery message still given after ifixit replacement
The “Service Battery” message is still be given in the battery drop-down menu after I replaced the battery with the iFixit kit. It seems like it was a successful installation other than that.
Score 5
Add a comment
RESET SMC
How to Reset the SMC on MacBooks
3 Comments:
Resetting the SMC is a temporary fix if the battery is faulty but good idea to try at least.
OP check the battery health with an application called coconut battery which can be downloaded online.
After SMC you may see the service battery message dissapear but reappear again if you drain the battery and charge it again indicating the system has found something wrong with the battery.
by
I also replaced the battery with the iFixit kit. The SMC reset didn’t help, I still get the message: “Service Recommended”. Is it a fault with the battery delivered with the ifixit kit?
by
Contact the iFixit store for a replacement.
by
Add a comment
This isn't a problem with the new battery, once the chip detects that the original battery has degraded past 80% (or so) or has started to rapidly degrade and inflate, the message will trigger and it's impossible to remove without paying for an official battery change from apple. This is obviously a way for apple to limit what people can fix and sell on (nobody will buy a phone with a "severely degraded battery message" even if the battery is effectively brand new and and 100%).
5 Comments:
That is not true! you need to reset SMC fully to clear the set value. Or the battery is defective.
by
So how do you do that ?
by
@esnew -Did you follow the steps in the guide rustedchip pointed to just above?
by
Im not sure where that is. Looking for rustedchip
by
@esnew - Here’s the same URL link How to Reset the SMC on MacBooks
by
Add a comment
Had a similar issue recently, tried two new batteries but service recommended message still present. Coconut Battery confirmed both new batteries were healthy. SMC Reset did not help but on a whim I tried an NVRAM Reset and bingo, message went away!
Add a comment
Add your answer
Gregory Brunkalla will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 3,155
