How to Reset the SMC on MacBooks
      • These MacBooks have a T2 security chip:
      • MacBook Air introduced in 2018 or later
      • MacBook Pro introduced in 2018 or later
      • If it has a T2 chip you can reset the SMC as follows (if not, skip this step):
      • Hold the "Control" and "Option" (Alt) on the left side of your keyboard and the "Shift" on the right side of your keyboard for 7 seconds.
      • Then additionally press and hold the power button and keep holding all four keys for another 7 seconds, then release them.
      • Press the power button after few seconds to turn on your MacBook.
      Ask FixBot
      • These models have a non-removable battery (per Apple definition):
      • MacBook Pro (Early 2009) and later
      • all models of MacBook Air
      • MacBook (Late 2009)
      • MacBook (Retina, 12-inch, Early 2015) and later
      • Proceed with the next step to reset your SMC.
      • For other models skip this and the next step.
      Ask FixBot
      • Shut down your Mac.
      • Unplug the MagSafe or USB-C power adapter from your computer.
      • Using the built-in keyboard, press Shift-Control-Option on the left side of the keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
      • Release all keys.
      • Reconnect the power adapter.
      • Press the power button again to turn on your Mac.
      Ask FixBot
      • Disconnect the MagSafe power adapter from your computer.
      • Remove the battery.
      • Press and hold the power button for 15 seconds.
      • Reconnect the battery and MagSafe power adapter.
      • Press the power button to turn on your Mac.
      • The LED on the MagSafe power adapter might change colors or temporarily turn off when you reset the SMC.
      Ask FixBot
The SMC of your MacBook has now been reset.
39 other people completed this guide.
mikeyd123
961 Reputation
2 Guides authored
6 Guide Comments
Il mio MacBook Pro 2019 nuovo di 3 mesi non vuole accendersi.
Ieri sera con la batteria 1% ho spento il mac. Stamattina non vuole avviarsi, non da segni di vita.
Il mac fa solo un suono quando attacco il caricatore, poi nulla. Dopo 2 ore in carica niente.
Cosa mi consigliate?
Grazie
Mario Scotti - Reply Share
merci ! fonctionne parfaitement depuis ?
David Derisoud - Reply Share
Mahalo, mikeyd123!
I just purchased a refurbished MBP 15 (11,5) mid-2015 Retina, macOS 12.2.1, and was having an issue with the fan running non-stop, from boot-up to shut-down. Resetting the SMC seems to have addressed the fan issue. Hopefully there are no thermal issues. If there are, iʻll check back in.
Kahana - Reply Share
I have this same model and am
Having the same issue but I can’t figure out which sequence of buttons! Please advise!
Gerene Townsend - Reply Share
I followed the reset instructions for my MacBook Retina 2017 (A1534) but now I get a Recovery Assistant & I'm asked to rest my password. I don't need to reset my password, I just want to reset to factory settings because a new owner will use this MacBook.
Ivana Sifuentes - Reply Share
Past 24 Hours: 59
Past 7 Days: 419
Past 30 Days: 1,921
All Time: 295,648
