Up to 20% off select tools
8.9" or 10.2" LED-backlit display, 1.6GHz Intel Atom N270, released October 29, 2008.
pc not turning on
after heating it shut down automatic and now its not turning on
Add a comment
Chosen Solution
naz, the possibilities are to numerous at this time to give you a definite answer. Start systematically to narrow it down. Make sure that your power supply is working. Take a multimeter and make sure that the output voltage is correct. I believe it to be 19volts for your mini. If you have power from your AC adapter, remove the adapter from the computer, remove the battery and remove the memory module. Leave it out for a while. Then replace the memory and the AC adapter and see if it starts. Also replace the battery after. If it still does not show any sign of life it is time to take it apart and visually inspect for any burned capacitors, you will recognize those by a bulging top. Also make sure that you clean the fan and the air vents and make sure that your computer has good airflow. The service manual is available right here http://h10032.www1.hp.com/ctg/Manual/c01...
Score 2
1 Comment:
عاوزه كل حاجه تخص عطل أنه الجهاز مش بيفتح نهائي
by Share
Add a comment
I am trying your sugestion.
I did remove the memory to add a 2GB memory,, the mini had been off 2 days when I did this, and the the battery was in and the charger wis disconnected, but plugged in
I will let you know
youtube had no help at all koddos to you
Add a comment
Please make sure your power supply is working properly. if is properly connected but still you are having the same problem, you need to check your motherboard and processor fan. it might be problem from there.
Add a comment
Add your answer
naz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 4,006
