The Panasonic Lumix ZS50 (Northern America) or TZ70, Tz71 is a small, lightweight personal travel camera, released in March 2015. The camera features a long lens from Leica (30x zoom, 24-720mm), heightened low-light sensitivity, built-in viewfinder, and a 12.1 megapixel resolution.
Lens will not retract
I now get a message ‘System Error’ (Zoom) when I turn it on. Is this an easy fix?
Score 2
Add a comment
1 Answer
Most Helpful Answer
@camera56 easy? That is a depends. For some tips and tricks to try and repair it use the ideas on here If those do not work then you most likely will have to replace the lens. That’s the part that is not so easy but absolutely doable. Here is the guide for that Panasonic Lumix ZS50 Lens Assembly Replacement
Score 2
Add a comment
Add your answer
Sandra Bokan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,135
