Panasonic Lumix ZS50 Lens Assembly Replacement
  1. Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: step 1, image 1 of 2 Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: step 1, image 2 of 2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
    Ask FixBot
  2. Panasonic Lumix ZS50 Lens Assembly Replacement: step 2, image 1 of 2 Panasonic Lumix ZS50 Lens Assembly Replacement: step 2, image 2 of 2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
    Ask FixBot
  3. Panasonic Lumix ZS50 Lens Assembly Replacement: step 3, image 1 of 1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
    Ask FixBot
  4. Panasonic Lumix ZS50 Lens Assembly Replacement: step 4, image 1 of 1
    • The battery should now be released; you may now remove the battery from the camera body.
    Ask FixBot
  5. Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: step 5, image 1 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: step 5, image 2 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: step 5, image 3 of 3
    • Orient the camera so the bottom is facing up and the battery door is on the right side.
    • Remove four black screws from the bottom of the camera.
    • Remove two black screws from the right side of the camera.
    • Remove one black screw from the left side of the camera.
    Ask FixBot
  6. Panasonic Lumix ZS50 Lens Assembly Replacement: step 6, image 1 of 2 Panasonic Lumix ZS50 Lens Assembly Replacement: step 6, image 2 of 2
    • Remove the casing from the camera by hand or using a plastic opening tool.
    Ask FixBot
  7. Panasonic Lumix ZS50 Lens Assembly Replacement: step 7, image 1 of 2 Panasonic Lumix ZS50 Lens Assembly Replacement: step 7, image 2 of 2
    • Use a spudger to lift up and tug off the green button board.
    • Be careful to not damage the attached ribbon cable.
    Ask FixBot
  8. Panasonic Lumix ZS50 Lens Assembly Replacement: step 8, image 1 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement: step 8, image 2 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement: step 8, image 3 of 3
    • Remove the screen using the plastic opening tool, prying from the top.
    • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
    Ask FixBot
  9. Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: step 9, image 1 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: step 9, image 2 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: step 9, image 3 of 3
    • Remove the three screws from the center of the copper plate.
    • Remove the four screws from the outer edges of the copper plate.
    • Use a plastic or metal spudger to pry the copper plate out of place.
    Ask FixBot
  10. Panasonic Lumix ZS50 Lens Assembly Replacement: step 10, image 1 of 2 Panasonic Lumix ZS50 Lens Assembly Replacement: step 10, image 2 of 2
    • Remove the casing from the circuitboard by hand.
    • Remove the HDMI port casing by hand.
    Ask FixBot
  11. Panasonic Lumix ZS50 Lens Assembly Replacement: step 11, image 1 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement: step 11, image 2 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement: step 11, image 3 of 3
    • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
    • Disconnect the circuitboard by hand.
    • There will be one orange ribbon cable attached to the top that can now be removed.
    Ask FixBot
  12. Panasonic Lumix ZS50 Lens Assembly Replacement: step 12, image 1 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement: step 12, image 2 of 3 Panasonic Lumix ZS50 Lens Assembly Replacement: step 12, image 3 of 3
    • Remove the seven screws surrounding the lens assembly.
    • Move all ribbon cables out of your way while unscrewing.
    • Remove the three springs surrounding the lens.
    • Apply pressure on the front of the lens to push the lens out.
    Ask FixBot
Bridget Lathrop
158 Reputation
2 Guides authored
Baylor, Team 8-5, Whitney Spring 2017 Member of Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 76
All Time: 2,790
