Up to 20% off select tools
The GSM version of the second generation Samsung Gear round smartwatch running Samsung's Tizen OS. The Gear S2 with 3G GSM was released in October 2015. Model number: SM-R730A.
Do u do Battery Replacement
Do u replacement battery on gear 2 smart watch and what do u charge
2 Comments
Do you replace samsung gear s2 watch battery?
How much does it cost and how long does it take?
by Share
Muchas gracias por la información.
by Share
Add a comment
Chosen Solution
Hi @deena_alhaddad,
If you read the answer above, it says that ifixit does not do repairs. Its’ volunteers provide information for you to do it yourself.
Use the information above to access the watch battery and search online to find suppliers of the battery.
Here’s just one link to give you an idea of the cost of the battery.
There are other suppliers online that may suit you better. Just search for Samsung Gear S2 battery to get results
Score 2
Add a comment
Most Helpful Answer
@fatdaddyslim
nope. iFixit does not do repairs. You can get guides, help and advice on here to do this yourself. If you are unsure, try an online search that may guide you to a repair shop that can do it for you.
This video as well as this guide Samsung Gear S2 Battery Replacement should get you inside your watch and allow you to change the battery.
Score 5
Add a comment
Add your answer
kducheneaux will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 51
All Time: 1,133
