Background information about the device "Logitech G602" (wireless gaming mouse).
Mouse wheel is not scrolling
I have a problem with my mouse scroll wheel. The scroll is not working at all but the wheel clicks just fine.
Score 2
1 Comment
I have recently started having this problem. I was sold it as brand new. It was working and it just stopped scrolling. Middle button works, but no scroll. There's no dirt or anything.
by
Add a comment
Most Helpful Answer
Logitech G602 Scroll Wheel Replacement
Score 3
2 Comments:
@ramirocampa Thanks for your help. The problem is not in the mechanical side of the scroll. When I scroll the wheel, it rotates well. The issues is that rotation doesn't get captured or sent to the computer i.e. no action happens
by
it might be a problem between the wheel and the digitizer. usually back in time there was a digitizer usually near the axis of the wheel. i dont know if it is suitable in your case but you might take a look at the "gears" or anytype of physical damage between the axis of the wheel and the support of it. in other mouses may be a worn out plastic axis... instead of being square shaped or any desired form it may be damaged (like too roundy) i hope this helps.
Regards
by
Add a comment
I had the same issue. Took it apart, and found the wheel clogged up with cat hair. Cleaned that up and it’s working again. Thanks for the pics on how to get it apart though :)
Score 1
Add a comment
scroll wheel was intermittent. Opened as above, removed ball of lint with tweezers from wheel area. Immediately worked correctly. Spudgers not necessary for this repair. Fingernail worked great.
PERFECT answer for my variety of this problem!
Add a comment
First i was thinking it doesn't work because of software. I uninstalled everything, but it didn't help .
Thank you. was dirty inside. fixed
Add a comment
Open it up (look for a yt tutorial if in doubt) and take it from there
Add a comment
Well I will suggest you to check out the following: https://www.systweak.com/blogs/logitech-...
Add a comment
Add your answer
eng_m_hamda will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 61
All Time: 8,154
