Up to 20% off select tools
Logitech G602 Scroll Wheel Replacement
Views: 11K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
148
All Time:
11,167
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help you adjust the scrollability of the mouse's scroll wheel by replacing the spring.
    1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: step 1, image 1 of 1
      • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
      Ask FixBot
    2. Logitech G602 Scroll Wheel Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
      Ask FixBot
    3. Logitech G602 Scroll Wheel Replacement: step 3, image 1 of 2 Logitech G602 Scroll Wheel Replacement: step 3, image 2 of 2
      • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
      Ask FixBot
    4. Logitech G602 Scroll Wheel Replacement: step 4, image 1 of 1
      • Use the black spudger to move the tip of the metal spring off of the wheel.
      • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
      Ask FixBot
9 other people completed this guide.
Author
with
Jerico Morales
1,303 Reputation
4 Guides authored
4 Guide Comments
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - Reply Share
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - Reply Share
"Logitech G602 Scroll Wheel Replacement" - completely misleading title. Thanks for wasting people's time.
Myshka - Reply Share
Merci pour les recommandations. Elles m'ont permis de voir qu'il y avait un fil dessoudé. ça m'aurait bien gêné d'en racheter une autre.
Didielus - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 148
All Time: 11,167
