Up to 20% off select tools
Released in 2007. Identified by the model number FE-210 on the front of the camera.
How to replace battery cover
Olympus FE210 with a broken battery cover. how to replace it with a new one. it is help in place by a pin much like a watch band. do you have to take the whole camera apart- remove all 7 screws to replace the door?
Add a comment
1 Answer
Chosen Solution
You won't need to take the entire camera apart in order to replace the door. You will, unfortunately, need to remove the front casing of the device which will require you to unscrew those 7 screws. The guide on how to do so is here:
Removing Olympus FE-210 Rear Casing
It's pretty simple and shouldn't take too long.
Score 2
Add a comment
Add your answer
Donna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 2,550
