Up to 20% off select tools
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
No output devices found
Hello All,
I recently installed a new display assembly on the macbook and had some issues. I finally got the display working when i realized that the audio cable was in backwards pins side up instead of down (dumb mistake). When i put everything back together I was worried that the sound may not work. sure enough its not working. not internal speakers are seen by the computer. the error is no output devices found. I reset the PRAM. and even reinstalled OSX. I have checked all my internal connections to the logic board. i ran a hardware diagnostic and its not seeing any issues. I am worried that the audio board and the cable might be fried... any ideas would be awesome.
PS. plugged in headphones and no go.
Score 3
Add a comment
1 Answer
I know this question is old but you most likely tore the audio board flex cable when you disassembled the machine
Add a comment
Add your answer
Yelitza rodriguez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 753
