Up to 20% off select tools
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
How do I replace the hinge
I have found replacement hinges on ebay and have seen videos on youtube for other models. But I'm not sure how to replace the hinge on the X200MA. The rear cover to the monitor is splitting away from the left hinge, and I'm wondering if it is possible to pull off that rear panel to access the hinge? There are no screws for removal like there are with the bottom panel (beneath the keyboard).
Add a comment
1 Answer
Most Helpful Answer
@kittyliz , Kitty, Below are tear down links that should get you into your laptop to change the hinge. Good luck.
Asus X200MA Fan Replacement
https://www.youtube.com/watch?v=q1s7oVFQ...
https://www.youtube.com/watch?v=32jw3x2K...
Score 3
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 561
