Up to 20% off select tools
Asus X200MA Fan Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
85
All Time:
3,016
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Asus X200MA Fan Replacement, Back Panel: step 1, image 1 of 1
      • Remove the following six screws:
      • Six 4 mm screws using a Phillips #0 screwdriver.
      • Remove the following one screw:
      • One 14 mm screw using a Phillips #0 screwdriver.
      • The 14mm screw goes in the center.
      Ask FixBot
    2. Asus X200MA Fan Replacement: step 2, image 1 of 1
      • Take two rubber caps off the back side of the laptop.
      • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
      Ask FixBot
    3. Asus X200MA Fan Replacement: step 3, image 1 of 1
      • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
      Ask FixBot
    1. Asus X200MA Fan Replacement, Battery: step 4, image 1 of 1
      Ask FixBot
    2. Asus X200MA Fan Replacement: step 5, image 1 of 1
      • Remove the following two screws under the rubber caps.
      • Two 14 mm screws using the Phillips #0 screw driver.
      Ask FixBot
    3. Asus X200MA Fan Replacement: step 6, image 1 of 1
      • Flip up the following:
      • The two latches holding the two cables shown(white and black)
      • Pull the cables free from the latches
      • Lift the keyboard from the computer
      Ask FixBot
    4. Asus X200MA Fan Replacement: step 7, image 1 of 1
      • Remove the following screws from the inside of the laptop:
      • Two 4 mm screws using the Phillips #0 phillips screwdriver.
      • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
      Ask FixBot
    5. Asus X200MA Fan Replacement: step 8, image 1 of 1
      • Slide the battery up and out.
      Ask FixBot
    1. Asus X200MA Fan Replacement, Fan: step 9, image 1 of 1
      • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
      Ask FixBot
    2. Asus X200MA Fan Replacement: step 10, image 1 of 2 Asus X200MA Fan Replacement: step 10, image 2 of 2
      • Unplug the set of wires located at bottom corner on fan.
      Ask FixBot
    3. Asus X200MA Fan Replacement: step 11, image 1 of 2 Asus X200MA Fan Replacement: step 11, image 2 of 2
      • Lift up and out to completely the remove fan component.
      Ask FixBot
3 other people completed this guide.
Author
with
Vanessa Garcia
1,817 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 85
All Time: 3,016
