Up to 20% off select tools
The HP 7 1800 is a 7" Tablet made in 2013 by HP. It is a WiFi and Bluetooth enabled device with a 0.3MP front facing camera.
How to fix a broken screen
The outside screen is fine be in the inside I can't see the screen it look like a crack in the inside.
Add a comment
1 Answer
Chosen Solution
Hi
Here is a link to the ifixit guide to replace your screen.
HP 7 1800 Display Replacement
Here is a link to just one supplier of the part. Perhaps you should verify with them that the part is compatible with your model before you purchase if you decide to use them. There are others online if this one doesn't suit you.
http://www.ebay.com/itm/New-LCD-Display-...
Alternatively, if there is a part number stamped on the back of the LCD screen in your tablet, search online using just the number to hopefully find suppliers of the part.
Score 1
Add a comment
Add your answer
Alijah Frost will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 455
