Up to 20% off select tools
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
The square button is not work
The square button when I press on button is not work what I do
Score 10
2 Comments
you can replace the square button. you can order the motherboard from the IFIXIT site. and you can see how to fix also on this site.
by Share
Yo no lie all I just did was get some scissors and pull up tried to wedge it in the side and just keep doing that trying to take the square button out than just pull up Spotify and keep trying use square till it work I swear try it
by Share
Add a comment
Chosen Solution
Hi Amjad!
You can find our repair guides here for fixing or replacing the buttons on this controller:
DualShock 4 (CUH-ZCT1U) Buttons Replacement
We also sell replacement parts for the controller if you need them. These are the buttons:
DualShock 4 Controller Action Button Covers
Includes the plastic action button covers and the button gasket Image
Product
Score 4
Add a comment
Make sure to clean the connection to from the conductive film to the motherboard.
https://youtu.be/Lx3La8a169Q
Score 2
Add a comment
Thanks on the bottom of the phones keyboard, the square button doesn't work. How do I get it back working?
Score 1
1 Comment:
How to make this work
by Share
Add a comment
I was having issues with my left analog stick constantly drifting. Took the controller apart and cleaned it. Now it works great……except the square button doesn't work now. I'm thinking it's the clear film. May have a tear but I can't tell. Hope that info helps someone. Still working on my square button. Thinking about buying another mother board.
Score 1
1 Comment:
I did same thing as Jason above, took controller apart cleaned it thoroughly put back together and square button not working.
by Share
Add a comment
Exact same thing happened to me cleaned joysticks sensors and now square button doesn’t respond, I can see and feel it makes contact but no response I was thinking it was the ribbon strip because a couple of connections on the ribbon were folded back from disconnecting and reconnecting so many times maybe this could be the issue?
Add a comment
Add your answer
Amjad Badkook will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 85
All Time: 88,529
