Up to 20% off select tools
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
Engine will not turn over
After replacing my fuel pump, my vehicle started up. But then the next day nothing. Did not turn over. When i attempt to start it i get a clicking sound.
Add a comment
Chosen Solution
Hi,
Have you checked your battery cables are securely connected and that the battery is not flat?
Usually a clicking sound is the starter solenoid engaging but there is not enough power for the starter motor to turn over.
Score 2
Add a comment
You either have a bad starter,battery or alternator. Or you just have a bad ground on your fuel pump ground.
Try jumping the car and or tapping the starter with a hammer
Score 1
Add a comment
Add your answer
winkelmananthony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 878
