Up to 20% off select tools
HP's G72 laptop has a high-definition 17.3" diagonal display, a stylish design and decent specifications. It also makes a decent budget desktop replacement
No bootable device found
This is the second time this problem has occurred, the first time iit happened i changed the harddrive but the problem has appeared again!
Score -1
4 Comments
Hi,What is the model number of your HP?
by Share
Its hp g72.....
by Share
In bios harddrive is not detected.... I tried another its working fine.....
by Share
Hi,
The question to ask yourself is , why are the HDDs failing so soon, especially if the 2nd one was new.
by Share
Add a comment
1 Answer
Most Helpful Answer
I would consider also changing the hard drive cable with the drive: HP G72 Hard Drive Replacement
What is happening to the drives and do they work in an external enclosure or universal adapter?
Score 2
1 Comment:
Its being detected as an external but u cant see any files in it... Can only see 2partions
by Share
Add a comment
Add your answer
Murtaza Kadibhai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 389
