Up to 20% off select tools
HP G72 Hard Drive Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
95
All Time:
8,467
Comments: 0
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
To work on this laptop, or any other device, it is important to shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn on the computer, and then shut it down through the operating system. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer. The failed hard drive is easy to remove and there are no hidden screws or tabs.
    1. HP G72 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 HP G72 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 HP G72 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
      • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
      • Turn the computer so that it faces upside down. Position the computer with the front toward you.
      • Slide the battery release latch to release the battery. Pivot the battery to remove it.
      Ask FixBot
    2. HP G72 Hard Drive Replacement: step 2, image 1 of 3 HP G72 Hard Drive Replacement: step 2, image 2 of 3 HP G72 Hard Drive Replacement: step 2, image 3 of 3
      • Loosen the two Phillips 2.5×6.0 captive screws that secure the hard drive cover to the computer.
      • The cover is snapped in by some clips. Use a plastic opening tool on both sides to remove the cover.
      Ask FixBot
    3. HP G72 Hard Drive Replacement: step 3, image 1 of 3 HP G72 Hard Drive Replacement: step 3, image 2 of 3 HP G72 Hard Drive Replacement: step 3, image 3 of 3
      • Remove the cover
      • Remove the four Phillips M2.5x5.0 screws
      • Disconnect the hard drive cable from the system board.
      Ask FixBot
    4. HP G72 Hard Drive Replacement: step 4, image 1 of 3 HP G72 Hard Drive Replacement: step 4, image 2 of 3 HP G72 Hard Drive Replacement: step 4, image 3 of 3
      • Remove the hard drive from the hard drive bay
      • Remove the hard drive cable from the drive.
      • Remove the four (two on either side) Phillips M3.0×4.0 screws that secure the hard drive bracket to the hard drive
      Ask FixBot
10 other people completed this guide.
Author
with
oldturkey03
867,181 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 95
All Time: 8,467
