The GoPro Hero3Plus Black Edition can be identified by its model number: CHDHX-302. It's an eighth generation camera that was released in October 2013. The GoPro Hero3Plus Black Edition is a Wi-Fi capable, 4K resolution digital camcorder.
Why is my GoPro freezing?
My GoPro Hero3+ Black keeps freezing when I try to use it? What can I do to fix this?
Add a comment
1 Answer
Chosen Solution
This is a common problem and generally requires you to reset the GoPro. You must first remove the battery and the SD card from the device. Then, replace the battery and hold the shutter button. If the GoPro turns on, power back off and insert the SD card. You may need to reformat the SD card again using the GoPro before using it again. For more answers visit the GoPro Hero 3+ troubleshooting page: GoPro Hero3+ Black Edition Troubleshooting
1 Comment:
Didnt work for me. I tried all the updates, hard resetting, tried different SD cards, tried brand new battery, nothing worked. Hard reset does nothing except puts all the default settings back on the cam.
by
Add a comment
Add your answer
Chad Carlson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 4,171
