Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
GoPro keeps freezing up
The GoPro becomes unresponsive to the user.
GoPro must be reset
One of the most prevalent problems with the Hero3+ Black Edition is that it tends to freeze up. To fix a "frozen" GoPro and perform a hard reset, follow these steps:
  1. Remove the microSD from the GoPro.
  2. Remove the battery.
  3. Once the battery is removed, hold down the button on the top, known as the "shutter button".
  4. If the GoPro actually turns on, it will read "no SD card" on the mini display. You should now turn the GoPro off.
  5. Insert the microSD card again, and proceed to power on the device.
  6. Format the microSD.
  7. Take a test photo and fix your GoPro's settings.
GoPro stops when recording
The GoPro begins to record video but will then stop recording on its own.
microSD card must be wiped
Delete all files off of the SD card in order to get rid of "ghost" files that may reduce available memory and cause bugs. After deleting all files, allow the GoPro to re-format the microSD card. Repeat this step if the problem continues to occur.
SD card "err" error message appears on display
The GoPro displays a message that reads "err" on the front display.
Re-format microSD card using GoPro
This error message is sometimes caused when the microSD card was formatted by a previous device that was not a GoPro. In order to correctly format the microSD card, delete all files and insert it into the GoPro. Then follow the steps (from GoPro official website):
https://gopro.com/support/articles/forma...
Incompatible microSD card
The error message could also be caused from an incompatible microSD. Many times, low class microSD cards cause this problem and can be fixed when replaced by a higher class microSD card. GoPro officially recommends using LEXAR 600x class 10 cards.
WiFi remote won't connect to the GoPro
The WiFi remote fails to connect to the GoPro.
Connecting remote to GoPro
To connect to the remote, go to Settings > Wireless Controls > WiFi RC. Select the "current" option. Make sure the blue light is blinking on the front of the GoPro.
GoPro won't power on completely
The GoPro does not turn on and the LED on the back flashes slowly.
Battery has low power
First, just make sure that the GoPro's battery is fully charged. When charging, the front display must be off, and the red light on the front must be solid. When the light has turned off, charging is complete.
Battery needs to be replaced
Find out how to easily replace your batter using the GoPro Hero3+ battery replacement guide.
Author
with
Chad Carlson
1,148 Reputation
2 Guides authored
Cal Poly, Team 6-15, Maness Spring 2015 Member of Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Members
84 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 37
All Time: 4,904
