Cooler Master's mechanical gaming keyboard. Released with Cherry MX switches.
The light under key cap does not work!
Hello,
I have a problem with the light under the key caps.
Is there any way to replace or fix the light?
Thank you!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Yes, there is! If the keyboard works as expected, and the only issue is that the light under the key cap isn't turning on, you can replace the LED under the key cap by following this guide. If there are issues with the keyboard other than the light, you can look at the troubleshooting guide.
Score 2
Add a comment
Add your answer
Sukhyun Baik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,302
